Pages: [1] 2 3  All   Go Down
Author Topic: Down on power after a few miles  (Read 7747 times)
mikesomega
« on: 12 January 2014, 17:31:20 »
I've noticed that my car is sluggish once it warms up. OK when first starting.
I've been trying to save fuel so I can pay for Christmas lol, would that cause it
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Down on power after a few miles
« Reply #1 on: 13 January 2014, 09:31:49 »
What flavour car is it, what engine size, Petrol, Diesel, Auto, Manual, year, whats the symptoms, any fault Codes?,
mikesomega
« Reply #2 on: 13 January 2014, 17:57:54 »
Sorry, its a 2.5. I don't have the tools to interogate the brain.
mikesomega
« Reply #3 on: 13 January 2014, 17:58:28 »
There are no lights coming on
martin42
« Reply #4 on: 13 January 2014, 18:00:25 »
2.5 v6 or 2.5td???
« Reply #5 on: 13 January 2014, 18:11:00 »
You don't have a paperclip?  :D
Seriously that is all you need for 2.5 V6, some TD's can also be done as well. See here:
http://www.omegaowners.com/forum/index.php?topic=90633.0
Helps if you tell us what engine exactly you have  ;)
mikesomega
« Reply #6 on: 13 January 2014, 20:17:21 »
A proper one, a V6 :D
You can keep your oil burners!
mikesomega
« Reply #7 on: 13 January 2014, 20:18:32 »
I shall try to get a paperclip. Not 2nite as its raining cats and dogs!!!
« Reply #8 on: 13 January 2014, 20:19:51 »
If you stick your location in your profile, you might find someone with a proper code reader lives nearby and can assist......    :)
mikesomega
« Reply #9 on: 15 January 2014, 08:20:44 »
I followed the guide with the paperclip, and got nothing.
Any other ideas?
zirk
  • Epping Forest
« Reply #10 on: 15 January 2014, 09:45:49 »
Are you doing it correctly, correct pins, etc, does the EML Light come on with Ing. on?
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #11 on: 15 January 2014, 10:28:59 »
Whereabouts are you?  ???
AKA - Mr Bracket
« Reply #12 on: 15 January 2014, 12:34:27 »
I'd be very surprised to see an Omega of that age with no codes what so ever. Sure you are doing it right?
« Reply #13 on: 15 January 2014, 13:07:26 »
FWIW, I had this problem on a car once. It turned out to be that the intake air ducting had come adrift just behind the radiator and the engine was ingesting hot air from behind the rad. As soon as the thermostat opened, I got hot air in the intake and, surprisingly, this cause enough of a power loss for it to be immediately noticeable.
On an Omega, this is less likely, since an air leak into the multiram ducting would bypass the MAF and cause more serious running issues, but it might be worth checking the ducting for leaks. In addition, check if the inlet to the airbox from the pipe in front of the radiator is still connected and, of course, if a "performance" air filter is fitted this is likely to cause the same symptoms.
mikesomega
« Reply #14 on: 15 January 2014, 17:34:51 »
I followed the guide and I think I have connected the paperclip OK
Does that mean there is nothing wrong wif it
Pages: [1] 2 3  All   Go Up
