Author Topic: Coolant transfer pipe - O rings plus glue?  (Read 1538 times)
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
« on: 12 January 2014, 19:43:23 »
Some threads earlier I asked about size of bastard bolt as up to now coolant transfer pipe was held on its place only by praying. After I moved it a bit major coolant leak appeared  >:( tomorrow I'm gonna give it a go but before starting the operation I would like to know if a double O ring swap was enough or I should get some extra glue, too?   ???
TIA
Laszlo
C20NE - X25XE
martin42
Re: Coolant transfer pipe - O rings plus glue?
« Reply #1 on: 12 January 2014, 19:58:53 »
O rings only,you might get a away with it,or buy the transfer pipe with o rings as you may damage it getting it out. :y
« Reply #2 on: 12 January 2014, 20:04:41 »
Not being bolted to the block can potentially allow it to come adrift under pressure :-\
AndyStobbs
« Reply #3 on: 12 January 2014, 20:12:06 »
Inspect the stat housing while you're at it. Too much corrosion in there and it won't seal in a month of Sunday's.
« Reply #4 on: 12 January 2014, 20:17:08 »
Laszlo, have you changed the thermostat recently :-\ iirc, someone out that way has done in the last month or so...
Johnny English
  • Hungary
« Reply #5 on: 12 January 2014, 21:22:55 »
Yep, you remember well, have done it without touching the bastard bolt, at the time it seemed possible didn't pay enough attention to the bolt  :-[  I haven't noticed the lack of bolt at all till yesterday. How didn't appear when I was doing that connecting the stat and transfer pipe was quite easy...?  :-\
C20NE - X25XE
« Reply #6 on: 12 January 2014, 21:51:52 »
The missing bolt probably made it alot easier ::)
Replace the bolt and all should be well :y corrosion not a real issue with the new thermostat casing as the transfer pipe plugs into it :y
Johnny English
  • Hungary
« Reply #7 on: 13 January 2014, 16:36:46 »
Sorted out Al!  :y O rings changed, B bolt replaced, no leaking , possible radiator coolant pipe swap will be in the close future as it looks not too good condition.  :'( Thanks a lot , guys!  :)
C20NE - X25XE
