Author Topic: water leak  (Read 2134 times)
peter the butcher
  • knaresborough, north yorkshire
  • omega driver as a hobby and now retired :-(
    • 2.6CDX
water leak
« on: 14 January 2014, 13:40:59 »
everything was "hunky dory", till we had a drop of rain, and I noticed the front passenger footwell  was wet, and it had creeped thru and soaked the rear one too. Its not rad water, as it does not smell at all of any antifreeze, but noticed a little lifting of the black rubber window seal, could this be the problem do you think???
Floor mats are dry now, but what is the best way to dry out the carpets, as it does seem to help mist up the windscreen with no air con on
Peter
Re: water leak
« Reply #1 on: 14 January 2014, 13:42:22 »
Scuttle drain is blocked, needs clearing ASAP or will kill your fan controller  :y
Details here: http://www.omegaowners.com/forum/index.php?topic=90535.0
Re: water leak
« Reply #2 on: 14 January 2014, 14:35:41 »
Ideally remove the front seats to get the carpet out and hang it in the garage to dry thouroughly. Don't even think about turning the ignition on with the seats unplugged though :-\
You also need a new pollen filter :y
peter the butcher
    • 2.6CDX
Re: water leak
« Reply #3 on: 14 January 2014, 19:32:01 »
Quote from: Taxi Al
[/quote
new pollen filter duly ordered, so will clean it all out at the w/e
madwon
    • Omega 2.2 DTI CDX Estate
Re: water leak
« Reply #4 on: 14 January 2014, 20:47:52 »
It does kill the hedgehog it has happened to me dam scuttle drains
Ady
  • Poole
    • Omega 2.6
Re: water leak
« Reply #5 on: 16 January 2014, 13:13:31 »
I've just had the same problem with a wet footwell on the passenger side. And sure enough after reading this thread my drain was blocked and quite a bit of water in there. So after a 10 seconds of putting in finger in the hole all the water drained out. And now just waiting for the carpets to dry. And need a new pollen filter lol, tho lucky the fan controller didn't die.
Love this forum  ;D
Re: water leak
« Reply #6 on: 16 January 2014, 13:28:30 »
.... And now just waiting for the carpets to dry. ....
It'll be a while, especially at this time of year. There's loads of sound proof foam under the carpet that'll soak up gallons of water  :(
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: water leak
« Reply #7 on: 16 January 2014, 13:55:26 »
The only answer is to remove as much as possible and then put a fan heater in the car to dry the rest otherwise it wont dry and will begin to smell.Been there keep a regular check on scuttle drain.
Ady
  • Poole
    • Omega 2.6
Re: water leak
« Reply #8 on: 16 January 2014, 20:39:36 »
Ok thanks
I'm going to get the vax to get the worst of it out then heater for the last of it.
Will be keeping an eye on that drain from now on.
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
Re: water leak
« Reply #9 on: 16 January 2014, 20:52:48 »
Had 4" water in front under scuttle, managed to force my hand down there to clear muck,luckily got away with carpets , this site is invaluable!!!
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
