Author Topic: Breaking 2001 2.6 Omega many good parts too damaged to repair  (Read 21289 times)
Martin_1962
Re: Breaking 2001 2.6 Omega many good parts too damaged to repair
« Reply #30 on: 28 January 2014, 20:54:29 »
Also now on Ebay. But here has priority.
Martin_1962
« Reply #31 on: 31 January 2014, 20:47:33 »
So far reserved
Spoiler
Bonnet
KYB Shocks
Climate
Wood trim
Poly bushes
Martin_1962
« Reply #32 on: 02 February 2014, 13:09:52 »
Both stalks (cruise), headlamp switch, Traffic Master all removed
£5 each + postage
« Reply #33 on: 02 February 2014, 13:40:33 »
How many miiles had it done, and what engine did it have (originally, if you messed around with it)?
Martin_1962
« Reply #34 on: 02 February 2014, 17:27:50 »
164,000
2.6 V6 Y26SE with 3.0 cams, inlet divider, and ported inlet ports to match divider.
« Reply #35 on: 02 February 2014, 18:07:45 »
164,000
OK, thats answered my query, I'll have to look elsewhere.
Thanks anyway :)
Martin_1962
« Reply #36 on: 02 February 2014, 22:10:34 »
164,000
Thanks anyway :)
I thought you knew!
I did mine not long after Mark did MikeDundees
So what are you after then?
« Reply #37 on: 02 February 2014, 22:26:47 »
So far reserved
Spoiler
Bonnet
KYB Shocks
Climate
Wood trim
Poly bushes
Total cost Martin :-\
Martin_1962
« Reply #38 on: 02 February 2014, 23:11:57 »
So far reserved
Spoiler
Bonnet
KYB Shocks
Climate
Wood trim
Poly bushes
Sorry spent most of weekend stripping out LPG :-[ :-[ :-[ :-[ Will get a price soon
« Reply #39 on: 03 February 2014, 09:04:17 »
So far reserved
Spoiler
Bonnet
KYB Shocks
Climate
Wood trim
Poly bushes
Is the LPG all removed now?
Martin_1962
« Reply #40 on: 03 February 2014, 11:53:51 »
So far reserved
Spoiler
Bonnet
KYB Shocks
Climate
Wood trim
Poly bushes
1 cut injector cable, the tank and the filler still to go, also need to find a few non fitted spares. Also I am trying to remove the loom without chopping it.
I will need your help to get the tank out.
Cut injector is a bugger of a job - I had to take the injectors out.
If Saturday is dry will be able to remove tank on Sunday.
« Reply #41 on: 03 February 2014, 18:09:22 »
164,000
Thanks anyway :)
I thought you knew!
brakes
Martin_1962
« Reply #42 on: 03 February 2014, 20:26:21 »
164,000
Thanks anyway :)
I thought you knew!
brakes
Well you can fit FL to PFL and I do have newish vented rear discs stil on the pads I fitted them with (and new shoes), and the rear calipers are OK, fronts, well who doesn't replace their discs every few pads as a matter of course.
I suppose it would be fitting for my old car to keep a few loved Omegas on the road, better than crushing a whole car.
amba
  • Medway towns
    • German V6
« Reply #43 on: 03 February 2014, 20:33:34 »
Could do with a really clean boot carpet if yours is nice ,n,clean :y
Martin_1962
« Reply #44 on: 03 February 2014, 20:55:25 »
Not very due to my tool box and it has holes from the tank :(
