Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Breaking 2001 2.6 Omega many good parts too damaged to repair  (Read 21267 times)
Re: Breaking 2001 2.6 Omega many good parts too damaged to repair
« Reply #45 on: 05 February 2014, 22:29:54 »
How many miiles had it done, and what engine did it have (originally, if you messed around with it)?
164,000
2.6 V6 Y26SE with 3.0 cams, inlet divider, and ported inlet ports to match divider.
OK, thats answered my query, I'll have to look elsewhere.
Thanks anyway :)
I thought you knew!
I did mine not long after Mark did MikeDundees
So what are you after then?
brakes
Well you can fit FL to PFL and I do have newish vented rear discs stil on the pads I fitted them with (and new shoes), and the rear calipers are OK, fronts, well who doesn't replace their discs every few pads as a matter of course.
I suppose it would be fitting for my old car to keep a few loved Omegas on the road, better than crushing a whole car.
MikeDundee's mechanic thought that as well, with predictable results  :'(
Martin_1962
« Reply #46 on: 05 February 2014, 22:48:40 »
164,000
Thanks anyway :)
I thought you knew!
brakes
But didn't he have solid discs inside of vented calipers?
« Reply #47 on: 05 February 2014, 23:19:46 »
I think the incident in question involved fitting solid discs to vented calipers :o
If I have read your last correctly, the car you are breaking has the following fitted...
Vented rear discs.
Wider calipers for said vented discs
Pads
Shoes
If all are refitted together exactly as they come off your car, then there should be no cause for concern :-\ provided of course that the discs and pads are only lightly and evenly worn...
A tidy brake upgrade for anyone with solid rear discs, TB included :y
Martin_1962
« Reply #48 on: 05 February 2014, 23:46:06 »
Vented rear discs.
Pads
Shoes
New pads would be a good idea while in bits but they are the ones I fitted with the discs in 2012
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #49 on: 06 February 2014, 09:42:22 »
Vented rear discs.
Pads
Shoes
Apologies for jumping in here
Are we saying that IF you have vented discs at the rear, you can fit front callipers to that hub / disc as a upgrade ?
« Reply #50 on: 06 February 2014, 09:45:48 »
Wasn't there a change in rear caliper piston diameter somewhere around the MFL->FL transition?
Be worth checking that first, as it could mess up the brake balance.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #51 on: 06 February 2014, 09:59:00 »
Just a mad / no cost idea due the extra weight behind the rear axel of the donut tank and the amount of weight I carry when if I get any work  :(
I've still got the old v6 estate on the side of the house so I could have pinched the bits of that  :-\
Can the rear brake balance be adjusted manually or is that all down to the Abs pump programming ?
« Reply #52 on: 06 February 2014, 12:16:55 »
What I was getting at was because Martins car had vented REAR discs with the wider calipers, both could be fitted to a car that has solid REAR discs without issue. Should also be stamped '42' on the outside face of the caliper.
Potentially, the front caliper will bolt onto the rear hub... BUT, rear discs are 10mm smaller in diameter, and vented discs are 20 mm thick at the rear/24 mm at the front. Front caliper piston area is about twice the size of the rear ones, so as Kevin has pointed out, fitting front calipers to the rear WITHOUT uprating the front brakes will almost certainly cause a problem. Also it is not known if the position of the front caliper will foul the disc when bolted to the rear hub :-\
« Reply #53 on: 06 February 2014, 12:19:27 »
What I was getting at was because Martins car had vented REAR discs with the wider calipers, both could be fitted to a car that has solid REAR discs without issue. THIS IS ONLY AS A COMPLETE UPGRADE. UNDER NO CIRCUMSTANCES SHOULD THE WIDER CALIPERS BE FITTED WITH SOLID DISCS
Edited rather obviously...
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #54 on: 06 February 2014, 13:16:34 »
Oh well, another mad idea out of the window  ::) ;D
I'll just have to learn to drive slower  ;D
« Reply #55 on: 06 February 2014, 13:39:55 »
Thee and me both ::)
If you've the parts to try it, hypothetically speaking of course, and only to establish that they physically fit... then please add your findings to the Brake Upgrades thread in Car Chat, as I was thinking along similar lines for the rear once the fronts have bigger discs/calipers fitted :-\
twiglet
  • Norwich, Norfolk
« Reply #56 on: 06 February 2014, 14:54:51 »
And I have a box of front calipers in the shed!  ;D :-X
« Reply #57 on: 06 February 2014, 14:58:39 »
TB was enquiring about front calipers James
Martin_1962
« Reply #58 on: 06 February 2014, 15:32:54 »
If you have changed your mind please let me know.
Wheels and tyres are currently available.
twiglet
  • Norwich, Norfolk
« Reply #59 on: 06 February 2014, 18:20:58 »
I also mentioned to TB that I had some VGC low mileage solid rear calipers in a recent post, but he never got back to me.  :-\
Pages: 1 2 3 [4] 5  All   Go Up
