Author Topic: Alternators  (Read 4155 times)
Alternators
« on: 19 January 2014, 10:47:45 »
Hi all!  :)
I need a new alternator for my 2000 2.5 V6 and have a couple of queries.
I've seen several alternators listed for models up to 1999, but would it fit my 2000 face lift? As far as I know its the same engine, X25XE...  :-\
Is there any value in fitting a bigger alternator?  I think the 3.2 has a 140amp as opposed to 120amp for the 2.5.  :-\
Thanks!  :y
Re: Alternators
« Reply #1 on: 19 January 2014, 10:51:02 »
I would have thought it depended on Spec rather than engine size... after all a 2.5 Elite has all the electrical kit a 3.0 does ::)
Variation might be with the connections or pulley size :-\
Re: Alternators
« Reply #2 on: 19 January 2014, 11:09:06 »
Ah good point didn't think about the pulley size.  i assumed they'd be the same size and basically in the same casing.  :-\
kevinp58
  • kent
    • 2002 3.2 elite
Re: Alternators
« Reply #3 on: 19 January 2014, 12:05:22 »
I would imagine that any V6 alternator would fit any other V6 as long as the plug is the same  :-\ and as has been said the elite and plods will have higher output.  :y
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
    • Grischke Solutions
Re: Alternators
« Reply #4 on: 19 January 2014, 13:13:06 »
I fixed my alternator last year (august 2012). I replaced everything, diodes and the voltage regulator and it works brilliantly.
I didn't have to replace diodes, but I did. It cost me £90, but I remember the voltage regulator was around £45.
They quoted me £250 for a new (read: refurbed) alternator so this means my alternator is now worth £250 :P
It's 120 amps.
chrisgixer
Re: Alternators
« Reply #5 on: 19 January 2014, 13:16:37 »
I fixed my alternator last year. I replaced everything, diodes and the voltage regulator and it works brilliantly.
They quoted me £250 for a new (read: refurbed) alternator).
Which, on exchange of the old one, you would of had a refund, no?
Making total cost of a new alternator about £110 odd. Iirc. Although there may have been a price increase since.
Just make sure they give you the right one. As the 3.0 doesn't fit. Spades are too wide and there not enough slack in the loom to the terminals.
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
Re: Alternators
« Reply #6 on: 19 January 2014, 13:18:16 »
I heard of it, but I don't remember anybody telling me about the refund there and then. Still £20 cheaper and now I know how to fix'em :P :D
chrisgixer
Re: Alternators
« Reply #7 on: 19 January 2014, 13:19:53 »
You forgot to do the guide for other members then? ;)
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
Re: Alternators
« Reply #8 on: 19 January 2014, 13:22:18 »
Yes and I regret it. I think I might have some pics somewhere.
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
Re: Alternators
« Reply #9 on: 19 January 2014, 13:49:31 »
I found some pics:
chrisgixer
Re: Alternators
« Reply #10 on: 19 January 2014, 14:28:52 »
Reckon that's enough. Got part numbers for diode and reg? :)
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
Re: Alternators
« Reply #11 on: 19 January 2014, 15:54:57 »
I should have the packaging somewhere. If I find it I'll post it.
Re: Alternators
« Reply #12 on: 19 January 2014, 16:21:04 »
Eurocarparts do a Lucas alternator which is about £250 but you get a refund when you send your old one back and it works out at £128.
I've found a couple of companies on ebay selling refurbed alternators for £60-70 with no exchange which seems like the way to go to me as they also give 12 months warranty.  :)
Then of course there's the scrappy route where they can be had for £30 or so, but might have done as many miles as my old one!  :-\
Re: Alternators
« Reply #13 on: 19 January 2014, 17:11:12 »
Scrappy and refurb it could be the way forward... refurb old one once out, and even if they only last a year you're never stuck without :y
Re: Alternators
« Reply #14 on: 19 January 2014, 17:38:47 »
This is the one I think I'll get, as I need to get one to whack straight in to get mobile again.  ::)
http://www.ebay.co.uk/itm/120895403677?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Might have a go at refurbing the old one though.  :y
