Author Topic: Catalytic converters  (Read 1597 times)
combatzone
  • Northern Ireland
    • 3.0 mv6
« on: 26 January 2014, 20:22:17 »
Just a quick question about catalytic converters.
Would the two cat sections on a 2.6 v6 be the same as the two on my 3.0 v6?
My car is a 2001 facelift 3.0 mv6
Thanks
Neil
Re: Catalytic converters
« Reply #1 on: 26 January 2014, 20:30:07 »
Think you might need to modify the flange on the manifold :-\
« Reply #2 on: 26 January 2014, 21:34:07 »
No,
the 2.6 will have pre cat, and cat
the 3.0 just has a main cat,  pipes and lambda sensors..bt can be modified to fit.
Whats you plan?  3.0 cats onto a 2.6?
combatzone
  • Northern Ireland
    • 3.0 mv6
« Reply #3 on: 26 January 2014, 21:40:27 »
There are no cats in my 3.0, was thinking on putting 2.6 ones into it. Any idea where I could get two cat sections at reasonable price? Would be a great help, need them for mot.
Thanks
Neil
« Reply #4 on: 26 January 2014, 21:57:34 »
You cut bits off to make them fit the other way, so getting a gas tight seal may be tricky.
There are also 2 Lambda sensors where you only need one, so one would need removing, and the post cat one would need swapping.
« Reply #5 on: 26 January 2014, 22:02:52 »
Some useful info and pics in here from when mine were swapped (3.0 cats onto a 3.2)
http://www.omegaowners.com/forum/index.php?topic=104510
combatzone
  • Northern Ireland
    • 3.0 mv6
« Reply #6 on: 26 January 2014, 22:19:05 »
Modifying the 2.6 ones to fit is an option but as I am not the handiest with this sort if thing I think 3.0 ones that bolt in would be handier for me. Why the previous owner removed them I'll never know, does it help performance at all?
