Author Topic: estate rear wiper blade  (Read 3441 times)
wightyboy2
  • Isle of Wight
« on: 11 February 2014, 19:17:55 »
Hi apologies in advance for this lame question I have got an old omega estate M reg , the rear window has got quite a curved shape and for the life of me I cant get the wipe to wipe the full curve of the glass I have tried bending the arm around  a bit but still cant get it too wipe the length of the blade ? :( I know this might sound a daft question too a lot of you that can probably build a whole omega nut and bolt but it sure frustrating the bits off me lol  ::) has any one got an idea how to solve this little problem , cheers  :y
Re: estate rear wiper blade
« Reply #1 on: 11 February 2014, 19:25:21 »
You're not alone, so don't worry. I think many estate owners have got around it with particular wiper brands and a slight bend on arm, but even then, full contact seems problematic at the top of the window.
I'll wait for an estate owner to comment :)
wightyboy2
  • Isle of Wight
« Reply #2 on: 11 February 2014, 19:37:20 »
Thanks for that was feeling a bit embarrassed at the trivial nature of the question in view of some of the really in depth stuff that goes on , on here cheers. :y
« Reply #3 on: 11 February 2014, 19:41:45 »
Mine is much the same..
I remember reading that genuine Vx blades were better than others, but to be careful you didn't get given the 'new variant' blade that was actually a Corsa rear wiper blade? Something along those lines..
andymp
  • Wakefield, UK
    • 2003 Omega CD 2.2 dti Est
« Reply #4 on: 11 February 2014, 19:45:15 »
A pukka gm one fixed mine...
Artificial intelligence is no match for natural stupidity...
JDX
  • Hersham, Surrey.
    • '02 2.2dti CDX estate.
« Reply #5 on: 11 February 2014, 20:08:26 »
My rear wiper suffers the same problem. I have tried a few different brands but without any real improvement.
I'm now living with it & just don't look in the rear view mirror!  :D
wightyboy2
  • Isle of Wight
« Reply #6 on: 11 February 2014, 20:52:14 »
Thanks for the replies so a gm blade done the trick for you andymp sounds hopeful , where can I buy a 13 inch one from ? Cheers  :y
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #7 on: 11 February 2014, 21:21:13 »
I use one of the aero type blades on mine, the springy/bendy-ness of them seems to cover quite well.
GM one should be the best solution, but never tried one
Always misses the bit by the brake light though
HTH
2boxerdogs
« Reply #8 on: 11 February 2014, 22:18:28 »
Had the same problem with our estate, don't know if you have a Wilkinsons where you are,  bought one from them & it's perfect..
hotel21
  • The Kingdom of Fife
« Reply #9 on: 11 February 2014, 23:02:18 »
Buy a new arm, not just a new blade. The spring in the arm makes all the difference.
It did to me anyways..... :y
« Reply #10 on: 11 February 2014, 23:43:05 »
Agreed, had 4 estates, all made the 'batman' logo until a new arm from VX was fitted.
« Reply #11 on: 12 February 2014, 01:43:20 »
Have yet to try an aero blade on mine, but longer blades actually seem to be more effective at following the curves :y
Still miss the brakelight though ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #12 on: 12 February 2014, 09:37:55 »
Took me some time to realise that the only wiper to use on the estate's is a genuine GM one, have tried lots, branded and cheapoo, GM is the only one ive found that is good enough. But a full set of GM blades on TC is peanuts anyway,and they work well,and don't seem to lift off at 70mph(officer) ;)
Hoof'land storeman.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #13 on: 12 February 2014, 13:41:17 »
I can agree this, have tried several blades of various brands until I realized that the original part is really special, it is curved from factory to fit the glass. Unluckily they have (at least here) replaced this original blade with some Corsa blade which is NOT the same even though the lenght matches.
As the blade body seems to hold together better than the blade I have renewed only the rubber blade to existing body with good results.
« Reply #14 on: 12 February 2014, 14:11:38 »
I knew I wasn't smoking crack when I said about the Corsa blade  :y Couldn't remember who had said it at the time but it must have been you.. :)
