Author Topic: urgent ... oil filter canaster removal  (Read 2733 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 22 February 2014, 15:06:28 »
Help  :-[
I'm in the middle off doing the oil cooler / cam covers / oil & coolant change.
I've got the cap off and the old paper filter out.
Now trying to get the holder off so I can undo the oil cooler pipes
What size allen key do I need to remove the holder ?
Can't seem to find the right one  :-[
Re: urgent ... oil filter canaster removal
« Reply #1 on: 22 February 2014, 15:14:23 »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 22 February 2014, 15:19:02 »
I'm trying to get the paper filter housing off Jimbob so I can get better access to the 2 pipes that come down from the oil cooler  :)
The cap is off and the paper filter is removed ........... the rest of the holder looks like it comes away from the block after the mystery allen key is removed
http://www.omegaowners.com/forum/index.php?topic=90596.msg1155493#msg1155493
« Last Edit: 22 February 2014, 15:20:50 by tigers_gonads »
  • Auckland
    • Mazda MPV
« Reply #3 on: 22 February 2014, 15:21:40 »
In the guide Convert your oil filter, canister to Spin on it says 27mm socket OR 12mm Allen key (depending on what parts where available on the day your engine was screwed together)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 22 February 2014, 15:26:27 »
I hate this piggin car  ;D
I'll dig a mirror out and have a look  ::) :-[
« Reply #5 on: 22 February 2014, 15:42:45 »
Ahhh, dont think you should be removing anything else then, just 19mm crows foot for the pipes, or am I still missing the point completely?
« Reply #6 on: 22 February 2014, 15:46:42 »
He needs to take the oil filter house off to access the 19mm oil cooler to block unions
So far he has only removed the cap to get the paper element out :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 22 February 2014, 15:48:37 »
Your a star James  ;D ;D
How the hell does the house come off ?
« Reply #8 on: 22 February 2014, 15:59:51 »
You're a star James  ;D ;D
« Reply #9 on: 22 February 2014, 16:07:33 »
I refer back to my 1st post ;)  27mm socket, or allen key, 12mm :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #10 on: 22 February 2014, 16:17:23 »
Okay, i'll admit it ............. i'm a cock  ::) ;D ;D ;D
Right, next (hopefully not too daft) question  ;D
The oil cooler is out but I can't see any obvious place were it has been leaking  :-\
In fact, it looks just the same as the known good one that i'm about to fit off the breaker.
I'm this far so its going to get done anyway BUT is they anywhere else that oil can get into the coolant ?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #11 on: 22 February 2014, 16:26:47 »
Normally on the very top plate of the cooler radiator, some minor rusting along the sides where its been joined ?
amba
  • Medway towns
    • German V6
« Reply #12 on: 22 February 2014, 16:59:54 »
Found on my old "R " reg that the cooler plate was pretty sound as was the actual coler radiator,but the sealant had all but perished and was certainly the cause of the weep.
Make sure that both surfaces are clean before apply the grey goo,and be very very carefull with the fine threads on the banjo bolts so as not to cross them..finger tightening only until you are totally certain they have gone in straight
