I think my mig maybe dead!
Started by omegod, 24 February 2014, 09:21:54
omegod
Went to start it this morning and it nearly caught then made a fluffy type noise, following cranking sounded very fast and certainly not normal at all, compression gone???. AA on route to see what the score is :'(
zirk
Quote from: omegod on 24 February 2014, 09:21:54
Hmmm, if its spinning, could be Cambelt gone, get the AA Man to check it first, before continually trying to crank it over.
omegod
Well stone me, false start meant petrol washed away the oil resulting in the low compression symptoms ! started eventually and running sweet :y
Borewash apparently!
zirk
Webby the Bear
Guys, what is bore wash? Out of interest.
RIP Paul Lovejoy
Bore wash is where unburnt fuel washes the oil from the bore sides and compromises the piston ring seal.
The question is......why all the unburnt fuel
omegod
Quote from: Marks DTM Calib on 24 February 2014, 14:15:00
Indeed, it caught a little then didn't start but I wouldn't have thought it would chuck enough much juice in to cause that problem?
Indeed.
By the way, if you do get signs of flooding, floor the throttle and crank it for a bit.
Webby the Bear
So basically it's over fuelling somehow? So first port of call would be looking to see if its going to closed loop or not?
RIP Paul Lovejoy
Quote from: Webby the Bear on 24 February 2014, 17:30:30
In this case no as it was a cold start so would have been open loop until it was warmed up (O2 sensors only operate when very hot).
It could be a weeping injector, flooring it and cranking for a few seconds followed a normal start would prove that
Webby the Bear
Quote from: Marks DTM Calib on 24 February 2014, 19:18:39
Yeah, should have realised that  :-[
RIP Paul Lovejoy
