Pages: [1] 2 3  All   Go Down
Author Topic: fitting traction control  (Read 5591 times)
davieboy0312
  • wishaw
    • 3l V6 saloon
« on: 02 March 2014, 10:19:52 »
Hi guys.
I got the engine, wiring and ecu from my old omega (3.0l v6 shell rotten) going to transplant into a newer shell. but the car I got is a 2.2 auto
question - used to have traction control new car doesn't, would I be able to get it back somehow.
Re: fitting traction control
« Reply #1 on: 02 March 2014, 15:48:59 »
Yes if you swap the following...
ALL the wiring from the 3.0
ABS Pump
TC switch
Will need to remove the dash from both cars along with the scuttle and pollen filter housing (only to make removing/refitting looms easier) :y
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #2 on: 02 March 2014, 16:44:42 »
i have all the engine wiring loom and have the abs pump as well. but the rest of the car is in scrappy heaven
« Reply #3 on: 02 March 2014, 17:26:51 »
Without all the wiring from the dash to the engine bay/abs unit it's likely to be a non starter :-\
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #4 on: 02 March 2014, 19:46:42 »
scrappy diving it is then. unless anyone got one I can purchase
    • E250 Est / Elroq
« Reply #5 on: 02 March 2014, 20:13:29 »
Im not convinced you will get it working regardless.
The ABS ECU needs to know the engine type its connected to, and talks to the Gearbox and Engine ECU's
There isnt an option to program it to a 2.2, so suspect it either wont work, or you will have a world of weird issues.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #6 on: 02 March 2014, 20:23:48 »
I have everything from original car. engine, gearbox, ecu and wiring loom and abs pump all from original car.
    • E250 Est / Elroq
« Reply #7 on: 02 March 2014, 20:27:22 »
ahhh misread sorry, thought you were trying to retrofit TC to the 2.2 :y
martin42
« Reply #8 on: 02 March 2014, 20:31:31 »
Thats what i thought aswell.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #9 on: 02 March 2014, 20:34:37 »
no point with TC on a 2.2
I had a 3.0l manual omega but was rotten at the crossmember at the front so stripped everything
got another car is a 2.2 auto and wanting to know if TC will work if I get a switch or will I need wires from switch to ecu or somewhere else
« Reply #10 on: 02 March 2014, 21:09:07 »
Do you have ALL the engine bay wiring, including the wiring from the ABS ecu to the engine ecu?
If not, get rummaging or pop a wanted ad in the test zone :y
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #11 on: 02 March 2014, 21:21:15 »
yea got the wiring for the abs unit to the whole loom fuse box in engine bay and everything. apart from dash loom
abs ecu???? what that look like
« Last Edit: 02 March 2014, 21:28:37 by davieboy0312 »
« Reply #12 on: 02 March 2014, 21:34:32 »
yea got the wiring for the abs to the whole loom fuse box in engine bay and everything. apart from dash loom
Including both sides of both round plugs next to the battery and the loom from these/the engine ecu to the bulkhead?
If yes to the last item, then you might just get away with splicing to the same loom on your 2.2 with an extra bit of wiring to fit the TC switch and relevant dash loom :-\ the 2.2 might even have the dash wiring in place... pop out the blanking plate from between the alarm switch and the boot switch (saloon only) should be 3 terminals there. If there are, obtain a facelift TC switch and fit it. When you press it, engine running, if the TC light comes on below ABS lamp, then things might be easier :-\
What age was the 3.0?
« Last Edit: 02 March 2014, 21:39:21 by Taxi Al »
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #13 on: 02 March 2014, 21:45:39 »
its was a 2000 on a W
the new one is a 2000 on a X
fingers crossed its got it.
« Reply #14 on: 02 March 2014, 21:52:38 »
Take it both cars are facelift then...
What the 2.2 won't have is the wiring from the dash to the engine bay/abs ecu...
Pages: [1] 2 3  All   Go Up
