Author Topic: Oil Cooler Seal Ring  (Read 3191 times)
Oak
  • Manchester
    • Omega
« on: 06 March 2014, 21:42:58 »
Hi all,
The garage that does my car said that I need to replace the Oil Cooler Seal ring. I took the car to the Garage because of oil leak. I was told that leak is from the Seal ring. I have contacted Vauxhall dealers and I was told that Vauxhall no longer make that part. They were not able to supply the part. The Vauxhall part number is 92065012. It is a seal ring for the oil cooler. The car is a 2000, 2.2, v16 Omega-B patrol.  Please does anyone know where I can get a Seal Ring for the oil cooler. Many thanks.
sjr47
Re: Oil Cooler Seal Ring
« Reply #1 on: 07 March 2014, 02:30:03 »
VX dealer more than likely confused thinking gasket under the cooler plate which is now replaced by a grey sealent though thats probably not the part you require speak to your repair garage for a clearer idea of the part failed look here http://www.omegaowners.com/forum/index.php?topic=90588.0 to give you a idea could be the aluminum sealing rings No 2 in illustration
« Reply #2 on: 07 March 2014, 08:04:28 »
No idea what the dealer is playing at, I checked and its available (all be it on a supersession)
Oak
  • Manchester
    • Omega
« Reply #3 on: 07 March 2014, 11:17:23 »
Thanks for your reply. Please Mark DTM, where did you see it? Please give me the details so that I can go and get it. Many thanks.
Oak
  • Manchester
    • Omega
« Reply #4 on: 07 March 2014, 11:38:23 »
Sjr47, I checked the  link you specified, and it seems that the oil cooler described in the page is different from the one found in Omega-B Y22XE. None of the parts listed in the page has a part number that corresponds to the one that I am looking for.  The part that I am looking for is part Number 92065012. Please any more idea of where I can look for it?
sjr47
« Reply #5 on: 07 March 2014, 11:44:08 »
Ye sorry brain fade did,nt realise it was a 2.2 most oil cooler problems on Omegas usualy on V6s as per photo so disregard my input (must pay more attention )!!  ::) ::)
davieboy0312
  • wishaw
    • 3l V6 saloon
Oak
  • Manchester
    • Omega
« Reply #8 on: 07 March 2014, 15:57:08 »
davieboy0312, Yes it is no 31 on the page. Any ideas where to get one?
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #9 on: 07 March 2014, 16:37:09 »
only place I can find is here
http://www.carparts-pros.com using part no 6 50 764 its a opel part number but its 55.00 euros delivered!!!
sorry best I can see
sjr47
« Reply #10 on: 07 March 2014, 17:22:32 »
If you end up down a blind alley searching for this part the last resort could be buying length of O Ring cord of the same diameter and fabricating your own we use this method at work when the required size is not in stores (More often than not) on hydraulic machinery sometimes rated at 200+ bar pressure (3000psi ), cut to required length and bond using Loctite  not sure if its 401 or 406 .if the  seal sits in a groove even better for forming & locating O ring.Just to add Viton rubber would be the choice for automotive applications.
« Last Edit: 07 March 2014, 17:30:37 by sjr47 »
Oak
  • Manchester
    • Omega
« Reply #11 on: 07 March 2014, 22:26:08 »
davieboy0312, I was at that web site last Saturday. I paid for the part, but on Thursday I got a refund from them saying that the part is not available. Many thanks for your help.
Oak
  • Manchester
    • Omega
« Reply #12 on: 08 March 2014, 13:37:01 »
  Sjr47, good idea, but fabricating my own seems a complicated thing to me.
sjr47
« Reply #13 on: 08 March 2014, 13:57:35 »
No 5 minute job using the old ring as a template splice it with a sharp blade then bond together using bonding agent (like superglue) might not get it right !st time but cord comes in 1m lengths so room for a few cock ups if you don,t get it perfect at first. :y :y
Oak
  • Manchester
    • Omega
« Reply #14 on: 08 March 2014, 20:58:06 »
Taxi Al, I checked but the item is not the one that I am looking for. Many thanks.
