Author Topic: rear silencer not fitting correctly ???  (Read 960 times)
cd 2.2
« on: 02 April 2014, 00:58:45 »
Right I have spent the last 2 days mostly on the floor under my car .... This has been in an effort to make the exhaust better as it was blowing at every joint!
All has mostly gone well, in the sense that it's back on the car and not blowing anymore! It's a 2.2 with all 3 boxes and the cat at the front. All of the exhaust had to come off of the car in one piece as none of it would split in situ. Once off the car I had to use the clarkson tool #1 (hammer) and a blowtorch to get the pipes to separate .... I found refitting was fairly simple, Fitted the passenger box first with new rubbers installed, Then fitted the new cat to that, then the drivers side box again with new rubbers installed ... And finally the rear silencer! Everything is nice and snug with no blowing joints but I have a problem, I can only fit the 2x rear rubber hangers to the rear silencer. The 2x front mounts on the rear silencer are touching the body mounts  ??? It's extremely difficult to move the system downwards to get the front rubbers fitted ... What have I done wrong?
The whole system is snug as it should be and doesn't catch the body in any way but the rear silencer mounts seem overly difficult to fit ??? Is this a normal thing to happen when doing this job?
Cheers Graham
Re: rear silencer not fitting correctly ???
« Reply #1 on: 02 April 2014, 01:21:02 »
Slacken the clamps where the back and centre pipes meet, then lever the front of the back box down, attach the rubbers the retighten the clamps :y
Not unheard of exhausts being a dog to fit, some are better than others... several factors can affect the fit regardless of supplier...
cd 2.2
« Reply #2 on: 02 April 2014, 01:26:58 »
Cheers Al ... will give that a whirl tomorrow  :y
Did notice that the pipes that go into the rear silencer were touching before I fitted the rear silencer onto the car .... Guess that is because all of the rubbers are new and allot tighter than what was left of the old ones  ::)
« Last Edit: 02 April 2014, 01:28:48 by cd 2.2 »
« Reply #3 on: 02 April 2014, 01:30:15 »
Possibly, but should still fit :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #4 on: 02 April 2014, 06:56:16 »
Sounds to me like the rear hanger hooks on the back box have got bent towards the box in transit, or during operations. You can easily bend them to fit with a Stillson wrench. Alternatively, you could get longer rubbers. Those hanger hooks do get bent, I find they often need adjustment.
