Author Topic: multifunction steering whee  (Read 3704 times)
opelman
  • Mysen- Norway
    • Opel Omega 2.5v6 cd cara
« on: 15 April 2014, 15:44:10 »
Hi
I have one 96mod opel omega b 2.5 v6 cd caravan, which originally did not have the multifunction steering wheel. Now I've switched steering wheel Multifunction steering wheel (taken from one 98mod), but I do not get the steering wheel buttons to work.
Re: multifunction steering whee
« Reply #1 on: 15 April 2014, 16:04:42 »
What headunit is fitted?
Two things spring to mind...
1. You need all the associated wiring loom.
2. The head unit might not be compatible.
The first item is a definite, the second a possibility :y
« Reply #2 on: 15 April 2014, 16:07:11 »
Hi
Loom only fitted mid `97 onwards in the mini facelift
opelman
  • Mysen- Norway
« Reply #3 on: 15 April 2014, 19:51:01 »
It is fitted a VDO CDR500 radio in the car, :)
« Reply #4 on: 15 April 2014, 21:00:45 »
Makes no difference what head unit is fitted, the loom for steering wheel audio controls won`t be present in your vehicle
« Reply #5 on: 15 April 2014, 21:26:32 »
Only mentioned the head unit as it might not support the controls... loom is rightly the first item to address though :y
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #6 on: 16 April 2014, 12:21:38 »
Wouldn't a compatible air bag squib be needed also...?
D.I.L.L.I.G.A.F...
« Reply #7 on: 17 April 2014, 00:50:29 »
Nope, all but one very early model were fitted with a minimum of drivers airbag :y
Might need the rotary coupling with the extra wiring, but airbag assembly should be fine :y
opelman
  • Mysen- Norway
« Reply #8 on: 17 April 2014, 10:29:31 »
I have switched slip ring / link to a straight number of wires. (Had to do it to get the connector to the airbag to fit). but the steering wheel still does not work. I also checked the wires Forward.  :)
    • E250 Est / Elroq
« Reply #9 on: 17 April 2014, 11:02:39 »
Im sure there is an option to enable / disable them using tech2.
Something along the lines of stereo = present.
Also amends the MID display.
