Author Topic: pit needed  (Read 1663 times)
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
pit needed
« on: 13 June 2008, 12:40:49 »
oil change now due
have the filter and the oil but no where to do it as the garage and pit haave been pulled down / filled in
dieseldonicely
Richie London
  • heathrow
Re: pit needed
« Reply #1 on: 13 June 2008, 12:52:20 »
i did mine on 1 axle stand, no problem. tell a lie i dropped the plug in the oil  ;D ;D ;D
Re: pit needed
« Reply #2 on: 13 June 2008, 12:54:39 »
Thats one of those things that tends to happen once, you keep a suprisingly strong grip on it the next time  ;D
Jack & Axle Stand is all I use
Re: pit needed
« Reply #3 on: 13 June 2008, 15:26:44 »
Im doing an oil change at the moment on axle stands, just waiting for the oil to drain.
omegaman2
Re: pit needed
« Reply #4 on: 13 June 2008, 15:29:43 »
but does your oil catcher not get stuck in the plastic under pan when you lower the car to get it level :question
dieseldonicely
Re: pit needed
« Reply #5 on: 13 June 2008, 15:33:12 »
Im lucky as my drive has a slight slope so I put the rear of the car at the top and then jack the front until its level, jobs a goodun :)
Re: pit needed
« Reply #6 on: 13 June 2008, 16:19:43 »
Kinda just clears it, you could always get a shallower catcher
Richie London
  • heathrow
Re: pit needed
« Reply #7 on: 13 June 2008, 16:22:33 »
i put my oil catcher in a large baking tray, not a drop on the drive  :y :y
Re: pit needed
« Reply #8 on: 13 June 2008, 16:26:14 »
I use on of these after seeing Mark use one
http://www.machinemart.co.uk/shop/product/details/14-litre-oil-drain-pan
Dont spill a drop, big enough and strong enough for all drainage jobs
Coolant / Oil / ATF
and a nice spout to drain from afterwards, cos when I used to use an old washing up bowl, took me longer clearing up spilled oil than the change did
Tony H
  • liverpool
  • Black Elites are luurvley
Re: pit needed
« Reply #9 on: 13 June 2008, 16:28:05 »
Take the oil catcher from under the car before you take it off the axel stand :y
