Author Topic: The family Corsa is pissing petrol.  (Read 4111 times)
« on: 24 April 2014, 17:41:25 »
I noticed a strong smell of petrol from our 53 plate Corsa today. Further investigation revealed a leaking fuel filter. :-\ :-\
The filter is the original, and I recently purchased a new one (£4) to replace it when I had a moment to spare.
I obviously need to do this sooner rather than later now.
Easy job?
Do I need any special tools?
Will I get soaked in petrol?
Re: The family Corsa is pissing petrol.
« Reply #1 on: 24 April 2014, 17:49:34 »
Same set-up as the Omega. Here`s the guide for the estate
http://www.omegaowners.com/forum/index.php?topic=90548.0
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 24 April 2014, 18:15:03 »
Yep,same bastard clips as most Vauxhalls :-\,has that thing been used to launch boats in the sea Opti :-X
other rides
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #3 on: 24 April 2014, 18:20:41 »
Are all these 1.0L and 1.2L corsa's 3 pot
Cheers henryd  :y Other half wants one but 3 pots dont sound right
« Last Edit: 24 April 2014, 18:27:03 by bigtimecube »
henryd
  • west cornwall
« Reply #4 on: 24 April 2014, 18:22:15 »
Only the 1.0 :y
other rides
« Reply #5 on: 24 April 2014, 18:28:54 »
The Corsa forum  suggest that the clips are easy to break and that a seemingly small job can become much bigger.
One disgruntled Corsa owner reckons that if you break the clips then you'll need a new piece of fuel line.
« Last Edit: 24 April 2014, 18:31:32 by Mr. Opti »
henryd
  • west cornwall
« Reply #6 on: 24 April 2014, 22:11:11 »
The clips fit on the filter itself,not the pipe,most aftermarket filters come with new clips but I don't think the GM filter does.
There is a special set of pliers for releasing the clips, I made my own by grinding out a pair of old side cutting pliers
other rides
andyc
  • Norfolk
« Reply #7 on: 24 April 2014, 22:56:03 »
I think they are talking about the pipe breaking not the clips, as said the clips are seperate. These Corsa pipes tend to break at the "Y" junction and if that happens its a new pipe and i think a tank drop to fit it
Andy
Thetford. Norfolk
« Reply #8 on: 25 April 2014, 00:19:26 »
Last GM one I bought for an Omega came complete with 2 new clips ;)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #9 on: 25 April 2014, 04:30:41 »
The first pic looks just the same as the one i had to remove from the MV6 estate the other week, and as you said fuel line did not want to come off even with correct tool :'( :'(. Needed to cut fuel line off in the end and fit a new one.  :( >:( >:( hope you have better luck than me as the Corsa has the "y" junction as you can see from your pic and that pipe on the filter looks very rusty just like the MV6 did. Sorry if that's bad news, i was under the estate for over an hour.
« Reply #10 on: 25 April 2014, 09:02:15 »
Oh dear, very poor maintenance Mr Opti!  ;D :y
Never had any issue removing them with the correct tools.
And if removed with the correct tools then the clips can be re-used, make sure you insert the clips into the ends of the fuel line fittings before fitting the new filter.
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #11 on: 25 April 2014, 17:10:57 »
If it is a bit dark when your the butler is changing it, just use a candle for a bit more light. :o :o ;D ;D
« Reply #12 on: 25 April 2014, 21:43:04 »
Local Vx dealer will change the filter for £25 inc VAT, if I provide the filter.
« Reply #13 on: 25 April 2014, 21:45:30 »
Oh dear, very poor maintenance Mr Opti;D :y
It may be the 2003 original but it's only had 25,000 miles of petrol flow through it....... ;) ::) ::) ::)
worzelof10acrefield
  • Peterborough
  • Don't snort coke......You might drown
    • Vauxhall Omega 2.6 V6 Est
« Reply #14 on: 25 April 2014, 21:53:08 »
By candle light would give a possible big light as a result in a bang....lol.....mmm
It's 106 Miles to Chicago, We've got a full tank of gas, Half a pack of cigarettes, It's dark and we're wearing sunglasses........HIT IT..
Page created in 0.029 seconds with 16 queries.
