Author Topic: Gear box had a duck fit  (Read 3531 times)
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
« on: 03 May 2014, 15:44:57 »
    Just back from Cornwall on the back of a recovery truck yesterday, first time ever. Selector lights flashing, erratic gear change and MCL coming on as well as the one with the spanner on.
  Selector switch malfunction diagnosed,  happened last day of Holiday.
     Have read the maintenance guide on cleaning and resetting the switch, which I shall start soon, I'm aching all over after the best part of nine hours being bounced around in three different recovery trucks :( :(
     My questions are, would this switch being dirty, cause all these malfunctions?
     For cleaning the switch does it have to be switch cleaner or will a good blast of Brake and Clutch cleaner be as good?
Regards
    Dave
Re: Gear box had a duck fit
« Reply #1 on: 03 May 2014, 15:47:03 »
Yep
Ideally
DaveA
  • Leicestershire
« Reply #2 on: 03 May 2014, 15:52:09 »
Yep
Ideally
  Tha :y nks again, Rob, switch cleaner it is.
Regards
    Dave
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #3 on: 03 May 2014, 17:07:12 »
Nothing to do with your problem, Rob, but what the hell is a "duck fit"? I've never heard that expression before, but once I understand it, I just might use it myself!
Ron.
DaveA
  • Leicestershire
« Reply #4 on: 03 May 2014, 17:46:16 »
  HI Ron
    You've never seen a duck in the water flapping round in circles, at speed, maybe diving under and popping up somewhere else, bumping into other birds, not knowing which way he/ she is going, maybe after a bit of ours-u-father.    Come north of Watford you'll hear a few more.   ;D
    Even Maggy Thatcher called an PM FRIT at question time and everybody down south (MPs)  looked  gone out,  until the BBC news explain what it meant.  ;D ;D :y
« Last Edit: 03 May 2014, 18:02:42 by DaveA »
Regards
    Dave
DaveA
  • Leicestershire
« Reply #5 on: 05 May 2014, 18:09:39 »
       Job done car performing as normal, accept that the ECL (little Gearbox) is still on.   Will this go out in a short time, (that's assuming no other fault is present), or will it need to be cancelled ?
Regards
    Dave
the alarming man
  • medway kent
    • disco V8
« Reply #6 on: 05 May 2014, 22:21:17 »
like a duck = Calm a serene on the surface, but underneath kicking and trashing around :y
