Author Topic: Stripped sump plug on TD  (Read 4413 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 20 May 2014, 15:00:11 »
Sadly the sump plug has stripped again (see post from 2011), ( sump drain pump had packed up, so have done the last few changes the old fashioned way.) I guess it will be helicoil next, I can get a kit that size for £13. :'(
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Stripped sump plug on TD
« Reply #1 on: 20 May 2014, 15:02:53 »
Get 2nd hand sump.
Hoof'land storeman.
Shackeng
  • Ramsbury
« Reply #2 on: 20 May 2014, 15:10:35 »
Get 2nd hand sump.
Changing sump not an easy option on a TD. Plus the thread is just as likely to have gone or been weakened.:y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 20 May 2014, 15:14:36 »
So long as it ain't the actual cast boss that isn't split ... as (once upon a time) happened to moi >:(
TD sumps cannot be removed without dropping-off the front subframe. Sorry Shack ... :'(
Shackeng
  • Ramsbury
« Reply #4 on: 20 May 2014, 19:59:11 »
Sorry Shack ... :'(
...as I learnt from your post in 2011 Byron! Hence opting for helicoil. :(
« Reply #5 on: 20 May 2014, 20:34:56 »
I helicoiled mine. BMW did make the sump from monkey metal, replacement will just strip.
When I said I helicoiled it, more accurately, that DTM fella did it for me :P
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 20 May 2014, 20:36:56 »
I Helicoiled mine a couple of years back, did the job a treat. It was a doddle to do, and better than the original. As said, swapping sumps is a Pig on the TD. I bought a cheapo set off ebay, can't remember how much but it was cheap and good.
Omegatoy
  • UK
« Reply #7 on: 20 May 2014, 20:38:14 »
when i had this I bought a p******t :'( I think sump plug which was just a nice size up from the original, tapped it out and never had any more problems,cant remember the size now but it was just right :y
Shackeng
  • Ramsbury
« Reply #8 on: 21 May 2014, 09:36:13 »
Exactly what I did 3 years ago, and have only done 20k since, so 6 or 7 oil changes, only about 4 via the sump plug, and having had it strip once I was very light handed. I think the sump is made of chocolate!
Keith ABS
  • Maldon Essex
« Reply #9 on: 21 May 2014, 12:54:17 »
Try fiting a Sahlbus oil drain valve afterwards, M14 x 1.5 is the thread size. Mine cost 37 quid delivered. Makes oil changes a lot easier
Keith B
« Reply #10 on: 21 May 2014, 13:03:25 »
Keith B
Ha ha, ........oh MR The Boy I am sure had an interesting experience with one of those types of device pmsl
« Reply #11 on: 21 May 2014, 19:08:59 »
Keith B
I blame the fitter :P
« Reply #12 on: 21 May 2014, 19:12:41 »
Keith B
Check how low they hang, as mustn't be lower than the ribs/web of the sump each side of the drain plug...
...if it is lower, the landing after an 80mph launch does result in a catastrophic oil leak...
I never did find the drain plug/tap following this incident, but the helicoil it was screwed into survived without any damage. Threw in a spark plug, popped in some oil, drove home (slowly!), went back to a traditional drain plug.
Helicoil sump plug is the way forward on these engines :y
Shackeng
  • Ramsbury
« Reply #13 on: 21 May 2014, 21:22:28 »
Keith B
 :y :y :y
« Reply #14 on: 21 May 2014, 21:37:16 »
Keith B
Maybe Marks DTM can remember how long the easy drain/tap thingie lasted. I don't think I managed a week with it  :'(
Page created in 0.013 seconds with 14 queries.
