My ferritin levels are low again
Started by Field Marshal Dr. Opti, 20 May 2014, 16:22:41
Quote from: Bikerdon on 20 May 2014, 19:42:35
I suffer from low ferritin levels regularly too, due to crohn's disease. Biggest problem I found was that iron tablets just pi**ed the crones off and caused it to play up big time. Solved now by iron infusions via an I.V. when needed, only takes about an hour as an out patient compared to 3 months of pills and stomach upset. Instant fix and no more forgetting to take the pills. :)
You learn something new every day.
I didn't know there was a link between crohn's and low ferritin.
What exactly is Crohn's disease anyway?
Gaffers
Quote from: Mr. Opti on 20 May 2014, 19:48:13
There are many other symptomns associated with crohns than just low iron.  Yesterday was International IBD awareness day  :y
http://www.crohnsandcolitis.org.uk/Resources/CrohnsAndColitisUK/Documents/Publications/Booklets/Crohns-Disease.pdf
Bikerdon
Ah! beat me to it Monsieur Guffer, was just about to post the very same link.
Gaffers
Quote from: Bikerdon on 20 May 2014, 19:52:53
Must be quite low for Nurse Stemo to have to inject Lord Opti with custard :o
biggriffin
Quote from: cem on 20 May 2014, 20:41:15
how much low Opti..  :-\
i notice Dr cem ask the lord Opti fiirst how much(private consultant) but hasn't asked poor old emd because he's nhs. ;D
Hoof'land storeman.
Cem, My ferritin levels are currently at 12.4.
Apparently it should be the the band 25-200.
My 'white blood cell' count is also low at 4.1......it should be in the 4.5-10.0 band.
Nurse Stemo is going to need alot of custard then :-\
Quote from: Taxi Al on 20 May 2014, 21:52:31
STMO dressed as a nurse would probably look like Bernard Bresslaw in 'Carry on nurse'.... ;D ;D
Rods2
Here's some of pictures of nurse STEMO
and his assistants, who hold you down and take your mind off him administering his big syringe....
;D ;D ;D ;D ;D
My 10 year old has low ferritin levels....Can tell by looking at him often enough.....And he's never given blood yet ;)
Quote from: Mr. Opti on 20 May 2014, 21:50:03
I dont think you have malnutrition in that age.. :-\
first port of call , stop any kind of alcoholic drinks (which breaks proteins and cholesterol) .. asap..
stop any kind of drugs you are using (except the critical ones related to heart-tension)  so your liver will have a rest and start to deal with your body..
thyroid seems to be suspicious but you may need a deeper check..
increase your exercise rate more than double..  :y
ps: may I remind, if you increase your daily blood flow rate x times, your liver and endocrinal system  will have the chance to repair x times more and also dont neglect the positive effect of x times more oxygen
Quote from: Jimbob on 21 May 2014, 05:49:28
I presume there are many reasons for low ferritin levels, repeated blood donation being just one of them. :y
Low ferritins, unusual for a ten year old I would have thought.
Quote from: cem on 21 May 2014, 09:05:46
...and where would be the fun in that,  Dr Cem?.... ;) :)
