Author Topic: changing the battery  (Read 2168 times)
firemoth
  • Preston, Lancashire
    • Vauxhall omega 2.2dti est
« on: 27 May 2014, 21:10:29 »
Hi. I read on the manual that if replacing the battery it's got to be done within 15 seconds of ignition being turned off or the alarm goes off as has its own supply. Now my battery is dead. Struggles to start. I'm swapping with a known good one, but I've got a habit of doing it with engine running to not lose stereo settings etc etc. Will this cause any problems?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: changing the battery
« Reply #1 on: 27 May 2014, 21:33:57 »
I normally just unlock the car and leave the key in the Ing. I always leave a door open though just in the Ecu locking throws a wobbly. If you need to co it with the car locked just unplug the bonnet switch.  ;)
firemoth
« Reply #2 on: 27 May 2014, 21:36:16 »
I'm not worried about car locked / unlocked, windows down or up, or car sat on its roof (although I'd prefer not!) Just making sure I won't blow any ECU or anything by changing battery with engine running
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #3 on: 27 May 2014, 21:38:20 »
Are you saying that you run the engine without the battery connected?
NO, No and NO!!!!!
You will damage the alternator, as there is nothing to limit its output voltage, and likely the ECUs, etc.........
Ron.
firemoth
« Reply #4 on: 27 May 2014, 21:44:36 »
I always have before (in other cars) the alternator has the regulator built in. I know it creates little spikes which can hurt advanced very fancy ECUs, but the DTI isn't that fancy is it?
« Reply #5 on: 27 May 2014, 21:54:27 »
Give it a try & see how much it costs if it all goes t1ts up! as Bigron says, it's a recipe for an expensive disaster  ;)
firemoth
« Reply #6 on: 27 May 2014, 22:21:04 »
OK next one (related) is the CDR 2005 stereo coded? There isn't a code written anywhere and the audio guide manual doesn't list this model
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #7 on: 27 May 2014, 22:26:28 »
If you are concerned about radio code etc. (assuming you've not got the code) why not hook up jump leads from your car battery terminal connectors to your new battery, undo and remove the old battery, place the new battery in position, put the connectors on to the new battery and remove the jump leads. Cover the leads with rag to avoid shorting against the car body whilst doing the above.  :y
Failing that, undo the battery leads and clamp, ignition on, ignition off, whip off leads, replace battery, replace leads and your sorted. The 15 seconds warning is to stop the powersounder going off.  :y
I wouldn't be running it while changing the battery when there is no need to, bearing in mind the potential damage it could do.  :y
Edit:
Just re-read my post and it's not very clear what I meant.  ::) ;D
Jump leads from the car terminal clamps to the new battery terminals. Remove old battery, put new battery in place and nip up the terminal clamps. Then remove jump leads. That way the car has never lost 12V supply.  :y
« Last Edit: 27 May 2014, 22:38:25 by YZ250 »
« Reply #8 on: 27 May 2014, 22:31:06 »
If the car battery is that flat, the radio will probably want a code anyway (assuming the requirement for a code hasn't been switched off  :-\)
firemoth
« Reply #9 on: 27 May 2014, 22:32:47 »
It's not completely flat but only just starts in the morning. I give it a week before it just about doesn't start....
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #10 on: 27 May 2014, 22:35:31 »
+1. And ditch the power-sounder if it hasn't already been done!
Work is the curse of the drinking classes (Oscar Wilde)
firemoth
« Reply #11 on: 27 May 2014, 22:50:53 »
As it happens I was showing the car off to my brother, locked the car with the bonnet popped, told him to open the bonnet expecting him to have a heart attack. All it did was put the bloody hazards on. I looked like a right Muppet :P
