Author Topic: Wiper stalk/switch query  (Read 1520 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 03 June 2014, 13:45:44 »
Hi guys,
I'm just finishing off my final electrical assessments and out of the three i'm doing i've chosen one to look at the wiper functions.
Firstly is there a guide to removing the wiper stalk? i did look throught MG but couldnt find one. If not does anyone know how to remove it?
Secondly i'm right in thinking the stalk is the switch, right? And therefore all the variable resistors (for the different speeds) will be part of the stalk... is there a little control box or something coming off the stalk?
Lastly, to test the function of the low speeds i was thinking that if i back probed the wire going to the motor on low functions (from wiring diagram i think this is a brown wire but that could be wrong as my wiring diagram is not great) and looked for voltage coming out of it when low activated, if i dont see reduced voltage but find a voltage coming in to the switch then i can condemn the switch, right?
Thanks boyos :)
RIP Paul Lovejoy
Re: Wiper stalk/switch query
« Reply #1 on: 03 June 2014, 13:50:21 »
Remove steering column cowl (3 screws under, 2 behind wheel at 9 o/clock/3 o/clock) release plastic tangs holding switch connector, release cruise plug if fitted. Jobbed
Webby the Bear
  • Northampton
« Reply #2 on: 03 June 2014, 15:21:04 »
Cheers Rob,
Are the methods of testing sound?
RIP Paul Lovejoy
« Reply #3 on: 04 June 2014, 17:42:26 »
wiring diag and a meter
Webby the Bear
  • Northampton
« Reply #4 on: 04 June 2014, 20:39:45 »
that's it mate but just wanted to makesure my testing methods were correct :)
RIP Paul Lovejoy
flyer 0712
« Reply #5 on: 04 June 2014, 21:18:45 »
I asked a similar question the other day and a member very kindly put a link on my page to show me how to add variable wipers and there is a very good description with pics on the resistor board if it would help you ...but i do not know how to transfer it to you....but if you look it up on my page you may well see it  :y
Webby the Bear
  • Northampton
« Reply #6 on: 04 June 2014, 21:59:04 »
that would be great flyer thanks.
when you say on your page....  ???
RIP Paul Lovejoy
flyer 0712
« Reply #7 on: 04 June 2014, 22:56:17 »
Sorry not too good at computers........If you look on ...the general help page....the one you have posted you question on.....go down that page and look for ......the flyer 0712  dated the 2nd of june (this week ) and click on ...variable wipers.... and you will see what the vey kind member sent me ..... :y
« Reply #8 on: 05 June 2014, 01:28:47 »
Think guy means http://www.omegaowners.com/forum/index.php?topic=124095.0 Webby ;)
Webby the Bear
  • Northampton
« Reply #9 on: 05 June 2014, 17:41:57 »
thanks boys much appreciated  :y
RIP Paul Lovejoy
