Author Topic: Autobox Software  (Read 4007 times)
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
Autobox Software
« on: 10 June 2014, 21:21:42 »
Hi guys, I understand that there are different software levels for the automatic gearboxes as discussed on this forum many a time..
Am I still correct in saying that version 9 is the highest level? Mine is as per info on the left.
chrisgixer
Re: Autobox Software
« Reply #1 on: 10 June 2014, 21:25:04 »
Believe so.
iansoutham
  • SE London
« Reply #2 on: 10 June 2014, 21:25:37 »
Good, good. Thankyou dear Dr Sir
    • E250 Est / Elroq
« Reply #3 on: 11 June 2014, 10:14:51 »
Can be up to 0A iirc.
You need to plug into TIS to be sure for your individual car.
« Reply #4 on: 11 June 2014, 10:39:24 »
Version 9 is the latest I have seen for the 2.0 petrol
« Reply #5 on: 11 June 2014, 11:57:00 »
V9 is latest for all GS820 varients
Simon270172
  • Sheffield
    • 2.5 CDX V6 Estate
« Reply #6 on: 14 June 2014, 17:51:47 »
Sorry to jump on this, but would mine benefit from having this update/upgrade? Is it even possible on mine, or is it too old as I believe it's pre tech2 even though it's got an 16 pin obd2 connector in the fuse box.
It does do the cycling up and down thing I've read about in other posts, also I've never really been happy with it's eagerness to drop down a cog or three at the slightest bit of load in comparison to my old senator(same gearbox??) which just cruised up the steepest of hills like they weren't there 8).
The oil and filter have been done a couple of times and the old oil looked to be in good condition each time. There is a leak from, I think the selector on the side of the box but that's all. Does this sound normal?(not the leak ::))
Could it be engine related? i.e. lack of low end toque that's causing the gearbox to respond as described?
What do you guys think or who do I need to be talking to?
Thanks in advance,
Simon
Regards,
Simon.
« Reply #7 on: 14 June 2014, 17:52:47 »
What year is it?
Simon270172
  • Sheffield
    • 2.5 CDX V6 Estate
« Reply #8 on: 14 June 2014, 17:58:26 »
Well it's registered as a '97 but everything on it is dated '96.
Thanks for the quick response btw :y
Simon.
Regards,
Simon.
« Reply #9 on: 14 June 2014, 18:13:22 »
Simon.
Sounds too early. Last letter of VIN a S, T or V?
Simon270172
  • Sheffield
    • 2.5 CDX V6 Estate
« Reply #10 on: 14 June 2014, 18:24:44 »
It's V.
If it's too early for update is there any other help available?
Regards,
Simon.
« Reply #11 on: 14 June 2014, 18:25:55 »
It's V.
1997 Model Year. Too early for a firmware update. Not much you can do about it I'm afraid.
Simon270172
  • Sheffield
    • 2.5 CDX V6 Estate
« Reply #12 on: 14 June 2014, 19:05:40 »
Oh pants :'(....
Forgetting the gearbox, what options are available to me diagnostics wise? Is it possible to test for correct operation of all that air ram gubbins actuators and what not as it just doesn't seem to have much bottom end poke and "maybe" that's what is causing the car to drop gears early to maintain speed.
As far as I can tell there's no vac leaks and it seems to be plumbed correctly but might be wrong on that.
Car seems to go ok if you boot it, but I've no real reference to work from other than my old senator which would happily sit in top even towing a caravan up a gradient on the motorway where as this wants to use 2nd and a lot more petrol :'( :'( .As we're off to the alps in 5/6 weeks time I could do with all the help and advice that anyone would care to give :y
Thanks to The Boy for your timely response's.
Cheers,
Simon.
Regards,
Simon.
« Reply #13 on: 14 June 2014, 19:42:56 »
No (low cost) generic code reader will speak to your car. There is an FAQ article on code readers which I wrote several years ago, but is still mostly valid.
The multirams can be checked in stages - firstly visually when revving - front should move with gentle revving, rear should move with a sharp rev to redline.  Worth checking that the vac tanks can hold a good vac. Turn engine off, and 2 mins later pull off one of the vac feeds to multiram solenoid, you should here the vacuum hiss for a second or so.
//Edit: Does a 97 have 2 vac tanks?
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #14 on: 14 June 2014, 20:05:48 »
Mine does.  :y
If it aint broken, you aint trying hard enough
