Author Topic: 3.0 cylinder numbers? Where is cylinder #2? I got P0302 code  (Read 5093 times)
car5car
  • Florida USA
    • 01 Cadillac Catera
Thanks.
01 CADILLAC CATERA 3.0 engine (Omega)
chrisgixer
Re: 3.0 cylinder numbers? Where is cylinder #2? I got P0302 code
« Reply #1 on: 18 June 2014, 23:55:11 »
Front, nearest the battery.
Numbers are written on the cam covers, by pot 1. Front nearest air box.
« Reply #2 on: 19 June 2014, 20:50:23 »
middle cylinder, drivers side, assuming LHD :y
chrisgixer
« Reply #3 on: 19 June 2014, 21:06:56 »
That's cylinder 4.
« Reply #4 on: 19 June 2014, 21:09:59 »
That's cylinder 4.
Opps, misread the code. Sorry
OP - front cylinder, drivers side if LHD
« Reply #5 on: 20 June 2014, 00:30:16 »
Late Catera is DBW iirc, might be a precursor to failing camcovers, unlikely to be water ingress, as that normally affects cylinders 5 and 6 first...
Also possible, if the mileage is below 100k, that plugs have never been changed :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 20 June 2014, 08:34:41 »
Looking at car from the front.
Left hand is 1,3,5,
right hand is 2,4,6
Hoof'land storeman.
chrisgixer
« Reply #7 on: 20 June 2014, 09:08:04 »
Left hand is 1,3,5,
right hand is 2,4,6
That's look in from the battery side wing.
Surely you mean
5     6
3     4
1     2
If looking from the front
Unless its a vectra ;D  ;)
biggriffin
« Reply #8 on: 20 June 2014, 10:34:06 »
Which part of looking from the front don't you get.
left hand is drivers side,right hand is passenger side.
Hoof'land storeman.
chrisgixer
« Reply #9 on: 20 June 2014, 14:07:16 »
you meant this
5     6
3     4
1     2
front
but wrote this
1,3,5,
2,4,6
front       see? Vectra! :)
;D where's the front of your lap top? ;D    ;)
biggriffin
« Reply #10 on: 20 June 2014, 14:37:25 »
you meant this
5     6
3     4
1     2
front
but wrote this
1,3,5,
2,4,6
if i was referring to a vetra,i would have said, your just being pedantic,and picking fault as usual.
Hoof'land storeman.
« Reply #11 on: 20 June 2014, 14:45:06 »
Doesn't help that OPs car is a left hooker :y
« Reply #12 on: 20 June 2014, 14:55:34 »
Caterra was drive by wire and coil pack (hence why the cylinder heads had tapped holes from 98 onwards).
But yes, cylinder two is the one nearest the oil dipstick
« Reply #13 on: 20 June 2014, 14:58:25 »
cough, reply #5, cough ;D
biggriffin
« Reply #14 on: 20 June 2014, 15:00:38 »
that i did realize after i had put drivers and passenger side. :),not my fault they buy cars that have steering wheel on wrong side. ;D
Hoof'land storeman.
