Pages: 1 [2] 3  All   Go Down
Author Topic: running hot but no climate heat 3.2  (Read 5921 times)
Re: running hot but no climate heat 3.2
« Reply #15 on: 21 June 2014, 08:23:39 »
Check the main rad that its getting hot all over , any cold spots means partially blocked rad  :y
amba
  • Medway towns
    • German V6
« Reply #16 on: 21 June 2014, 09:15:31 »
Need to work at it systematically
First is the coolant bring pushed around so check flow:water pump
Is all areas getting coolant .flush system and check for cold spots or air locks blockages
Is thermostat operating as designed and opening
Is system running at pressure and no leaks etc
Are all electrical aides working as designed and us gauge registering the temp of coolant
« Reply #17 on: 21 June 2014, 12:14:05 »
Re the aux pump... That isn't entirely accurate... that pump only works when the engine is OFF to pump hot coolant through the heater matrix so you might use the heater when sitting in the car, say waiting at a level crossing, or when picking the kids up from school etc. It then only runs as long as there is sufficient heat to maintain the set temp. :y
It's possible the pump on the radiator is dead, so consider swapping those two pumps over. They are the same, and being never used, the one under the heater tank is pretty much guaranteed to work :y
Before getting stuck into the engine side of things, check the following:
1.Do all three fans run?
2.Is the HBV plumbed in correctly with vacuum hose attached?
3.When flushing, ensure the temperature is set to HI on both sides.
4.Are the arms to the blend valves attached/do they move when you adjust the temps on the climate panel?
If 2 and 4 don't work, you could replace the heater matrix, radiator, thermostat, water pump, aux pump on the radiator only to find no difference.
1,2 and 4 are all covered in the guides :y 4 being summat like ' Heater only working one side, how I fixed it'
HTH, Al :y
powerslinky
« Reply #18 on: 21 June 2014, 18:53:37 »
Pulled vac pipe from HBV   there is no vac  at this pipe   with heat on or off.   Presume that there should be at one or other .
Can anyone advise as too when vacumn should be felt at the HBV ?
Have flushed heater matrix  . . . little bit of brownish water  at first but clear & flowing really good  :-\  so thats ok  :y
« Reply #19 on: 21 June 2014, 19:32:05 »
Should be vac when set to LO :-\
Disconnect the other end of the vac line and suck on it, you should hear the valve moving :y
« Last Edit: 21 June 2014, 19:40:22 by Taxi Al »
powerslinky
« Reply #20 on: 21 June 2014, 19:51:20 »
HTH, Al :y
OK Al . . .  1.   only 2 fans running  . .  main one  engine side of rad   &  N/S front one  (battery side)  other front fan not working
2. HBV  seems correct as in maintenance guide diagram  but no vac at any setting ( could the cabin side of one of the pipes have come off ? )
3. Where do I find the blend arms   :-[     . . . any pics available  :-\
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #21 on: 21 June 2014, 20:08:21 »
HTH, Al :y
Air Con on?
« Reply #22 on: 21 June 2014, 20:10:48 »
HTH, Al :y
1. might be a relkay issue, or dependent on aircon working, won't help temp though.
2. might be a duff vacuum switch, possibly caused by a stuck hbv, or a faulty climate panel (ecu).
3. http://www.omegaowners.com/forum/index.php?topic=90575.0
powerslinky
« Reply #23 on: 21 June 2014, 20:21:35 »
HTH, Al :y
Thanks Al . . . . lots going on here . . . .  will get going on it   . . . but working again tomorrow  , so next week more likely :(
RE: the aux pumps  . . .  can I just test by pulling each electrical connector off & putting 12 volts to the 2 pins ?  :-\
« Reply #24 on: 21 June 2014, 20:27:41 »
Yup re aux pumps :y
zirk
  • Epping Forest
« Reply #25 on: 21 June 2014, 20:28:41 »
HTH, Al :y
If you know which Pin is + and -, sometimes easier to pull the relay cover off and make the contact by hand.
powerslinky
« Reply #26 on: 22 June 2014, 16:32:18 »
Happy days  ;D ;D ;D ;D       :y :y :y
Ok guys   . . . have changed the HBV   ( had one anyway  ;)  )      now all working   really good .
When on HI    the heat is excellent   & on LO   blows cool . . . not really  cold as am having to run it on ECO  as the A/C needs looking at .  Compressor not kicking in , hoping thats just a re gas :-\.
Running temp is also sorted      max temp on gauge is 90   fans kick in bring it back to 85 . :y :y :y
Tested aux pumps  . . . both work   but when should the one by the Rad switch in ?   as it does not seem to . is there a fuse to check for this ?
But delighted with progress so far   &  thanks to all who  advised etc.  :y :y :y
« Reply #27 on: 22 June 2014, 19:02:58 »
Nice one :y
Re the aircon... test the high pressure valve prior to doing anything else. If it still holds pressure, get it regassed first. No pressure then renew the valves and condenser prior to regassing :y not much else to go wrong with it after those three things, so might  as well start off right :y
Think the rad pump is as a final helping hand when the fans are struggling :-\ if the pump itself works, then I wouldn't fret it... it may even be triggered by the aircon :-\ so if that doesn't work then the pump may not...
powerslinky
« Reply #28 on: 22 June 2014, 19:58:50 »
Nice one :y
Al  , I'm thinking this test would be  done by  garage / aircon specialist  ?  . . or can I do it ?  :-\ :-\
« Reply #29 on: 22 June 2014, 20:03:25 »
Unscrew the plastic cap on the aircon pipe to the bulkhead, then simply press the tip of a small screwdriver onto the valve.
If it hisses, then the system is relatively sealed so a regas should see it working again... no hiss = no gas pressure, so most likely condenser is shot, but prudent to change the valves as well whilst the system is empty :y
Pages: 1 [2] 3  All   Go Up
