Author Topic: "Check" Light  (Read 1762 times)
kevinwoodley
  • oxfordshire
    • omega
"Check" Light
« on: 26 June 2014, 10:29:50 »
Hi guys,
Just noticed that the "CHECK" light has come on, (not very brightly, but can clearly see it) on the display that shows the temp etc. no other warnings on the display
03 Omega auto estate,  Any ideas???
Thanks in advance  :)
Re: "Check" Light
« Reply #1 on: 26 June 2014, 11:44:40 »
What engine?
Have you tried the pedal trick, as per here...
http://www.omegaowners.com/forum/index.php?topic=90633.0 :y
Hello btw :y
kevinwoodley
  • oxfordshire
    • omega
Re: "Check" Light
« Reply #2 on: 26 June 2014, 12:20:03 »
Hi
It's the 2.2 sports petrol.
Re: "Check" Light
« Reply #3 on: 26 June 2014, 12:48:13 »
Hi
An oxymoron if ever there was  ;D
Anyhoo, pedal trick may or may not work, so you'll need a code reader of some sort to tell you what's what :-\
Best bet will be to give Symes a shout, he's Oxford based and should be able to help :y
There are others, relatively close by, TheBoy has a genuine Tech2, and is up the road in Brackley, for example :y
« Last Edit: 26 June 2014, 12:51:59 by Taxi Al »
Re: "Check" Light
« Reply #4 on: 26 June 2014, 17:47:59 »
Still there after pressing brake pedal?
Near enough to Bucks/Northants border to swing it past Brackley?
joshwyatt
  • Oxford
Re: "Check" Light
« Reply #5 on: 26 June 2014, 19:51:35 »
I've got a decent code reader, certainly works on 2.2 Omega's...where in Oxon are you? I'm based in Kidlington.
Re: "Check" Light
« Reply #6 on: 27 June 2014, 17:45:32 »
Generic? Will only do engine ;), I suspect this needs something a bit more intelligent.
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: "Check" Light
« Reply #7 on: 27 June 2014, 20:06:09 »
Shall I give Rob g a shout ;D
