Author Topic: Spanner light on but driveable.  (Read 4944 times)
2boxerdogs
« on: 29 June 2014, 16:55:26 »
Been using the wifes 2.2 today, she has told me that a couple of times this week when first started up the spanner light came on & car was in "limp mode" turned car off & re started all was fine, I have used it today same happened but spanner light is staying on & car drives normally, my thought is cam sensor my mechanic can read the codes tomorrow no problem there, anyone on here had anything similar ? If it is the sensor what should the code read ?
« Last Edit: 29 June 2014, 16:57:02 by Tilbo »
Re: Spanner light on but driveable.
« Reply #1 on: 29 June 2014, 21:05:15 »
Rather than trying to guess the code, we need to read the code. Anything else is a guess, no matter how common cam sensor failures are
Hope that makes sense :)
2boxerdogs
« Reply #2 on: 30 June 2014, 18:36:46 »
Had codes read today ,
1, Cam sensor no signal.
2.PO 700 mil request from transmission control module. Can anyone on hear give advice on this one.
Thanks guys..
« Reply #3 on: 30 June 2014, 18:39:24 »
Replace the cam sensor then, as you had the P0340
2boxerdogs
« Reply #4 on: 30 June 2014, 20:47:54 »
Yes I have every intention of replacing the cam sensor, the query is regarding reading number 2 code PO700 re transmission control module, sorry if I appear "thick" .
« Reply #5 on: 30 June 2014, 20:54:23 »
Cam sensor codes often throw random other codes, the transmission is probably get odd signals hence code.
Changing cam sensor will make that go away  ;)
2boxerdogs
« Reply #6 on: 30 June 2014, 20:56:54 »
Thanks for that, I was hoping that may be the case am I better off fitting a genuine VX one ?
Temetsy
  • Finland
    • b1 x25xe sedan
« Reply #7 on: 30 June 2014, 21:01:19 »
Yes absolutely, I've heard much about car not even running with cheaper cam or crank sensors  :P
« Reply #8 on: 30 June 2014, 21:18:34 »
Yes. Genuine only for this :)
2boxerdogs
« Reply #9 on: 30 June 2014, 21:26:52 »
Right I am off  work after tomorrow for a few days so will order one, any idea what I should be paying roughly ?
2boxerdogs
« Reply #10 on: 02 July 2014, 14:51:06 »
Ordered the cam sensor today from my local dealer ..Part No V0090520850 £72.00 plus vat = £86.40.
Should have it Friday morning is it a simple swap over or should I get my mechanic to fit it ? Any tips welcome please (2.2 estate  petrol )
4x4
« Reply #11 on: 02 July 2014, 15:49:54 »
Check maintenance guides,there is a how to  :y
2boxerdogs
« Reply #12 on: 02 July 2014, 16:35:09 »
Thanks, checked the guide one for my mechanic I think.......
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #13 on: 02 July 2014, 17:43:19 »
Shame no one local with a trade card could have helped save you a bit, that will sort it as said and don't worry r.e the transmission code that always do that with a cam sensor
2boxerdogs
« Reply #14 on: 02 July 2014, 18:07:22 »
Yes, would have been good to have saved a bit but will just be glad to have it running  right again !!
Spanner light is on all the time at the moment  , sometimes goes into limp mode when first started , but when the ignition is turned off & on again is ok  tending not too go far in it at the moment .
