Author Topic: usb wireless dongle  (Read 2959 times)
pauls
  • By the sea minehead
    • Bmw x3
usb wireless dongle
« on: 19 July 2014, 12:29:39 »
Can somebody recomend. :y
Re: usb wireless dongle
« Reply #1 on: 19 July 2014, 12:58:53 »
To use in what? Laptop? Desktop? Windows? Linux?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 19 July 2014, 13:19:06 »
If it has to be a Dongle then probably Huawei in some shape or form, at least with them you can download there Own Connection Software rather than rely on the shitey Network Branded stuff that comes with it.
Personally cant remember the last time I used a Dongle, tend to use old or near broken Mobiles and stick em high up somewhere near a window in WiFi Hotspot mode, works a lot better. To get any decent speed out of Mobile Data its all about good Signal Strength.  ;)
pauls
    • Bmw x3
« Reply #3 on: 19 July 2014, 13:26:52 »
Sorry to use in a dell laptop. Just finding internal one isnt giving a strong enough signal.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #4 on: 19 July 2014, 13:31:45 »
I am guessing you are talking about improving your Wi Fi capability and not 3G dongle for accessing the Internet.
If it is the first one, I can recommend TpLink. Easy to use and very small. With its cap on they are about 1 inch long , half an inch wide and quarter of an inch thick.
zirk
  • Epping Forest
« Reply #5 on: 19 July 2014, 13:39:45 »
Ah, WiFi Dongle, note to me, must learn to read Tittle as well as Discription,  ::)
Wouldn't have though a Dongle would be any better (Strength wise) than the in built one. might be easier to sort the WiFi point issue out first or use a cheapo repeater.  :-\
pauls
    • Bmw x3
« Reply #6 on: 19 July 2014, 13:42:45 »
[/quote]Ah, WiFi Dongle, note to me, must learn to read Tittle as well as Discription,  ::)
[/quote]
I was just thinking that the laptop is rather old and I new dongle with newer software etc might connect better to the bt homehub 5.
zirk
  • Epping Forest
« Reply #7 on: 19 July 2014, 14:05:38 »
[/quote]
[/quote]
Without knowing what the issue is, guessing Signal Range, the newer software wont make any difference to signal strength. As you say could be old lappy, most have the WiFi Aerial in the Lid with the WiFi Gubbins on or near the Main Board or Lid, so could be a worn hinge cable, but just guessing really.  :-\
« Last Edit: 19 July 2014, 14:07:35 by zirk »
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #8 on: 19 July 2014, 14:44:32 »
I am hoping I haven't got the wrong end of the stick, but I found this WiFi adaptor to be excellent value and performs well, giving superb reception from my Sky Broadband downstairs to this PC upstairs.
The Auction Number is 221048809437 and is on a "buy it now" offer of £6.75 including postage.
I also bought a very natty and well made battery voltage monitor that plugs into the cigar lighter socket and gives a digital readout. I am amazed at the price of this item - £2.10 including postage - I could not buy the display for that money!
The Auction Number is 130860507738.
Hoping this helps.
Ron.
« Reply #9 on: 20 July 2014, 10:13:44 »
USB Wifi devices are always weaker than onboard Wifi (by nature of the more compromised antenna).  However, if the onboard one is old, it may only support B/G, so may be benefit in getting N capable, or if the router supports 5Ghz, getting a 5Ghz USB (note - 5Ghz more affected by walls etc).
It may be possible to replace the onboard PCI/PCIe one with a newer type, but double check the form factor and the antenna lead layout.
For USB ones, I have a couple of cheapo Edimax ones here (bought, because they work with Raspberry Pi), and they are "OK".
For a 54Mbps wifi, expect the throughput to be around 20Mbps max - well below superfast broadband speeds offered by fibre broadband packages from Virgin or BT based services. In hostile areas, it will be lower.
If all wifi devices are slower, it may be you are too close to another access point on the same/adjacent frequency (most channels overlap, except 1,6 and 12, and these tend to be the default channels that most routers use, and thus will cause problems if used). Windows tools such as InSSIDer will show what frequency local access points are on, including those with hidden SSIDs.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #10 on: 20 July 2014, 14:03:28 »
If you can live with something on the end of a usb cable, the Alfa AWUSO 36H is the best I can find.
Put it this way, I can sit in my car 50 yards down the road and still use my houses internet which is at the back of the house  :y
A little word of warning, being a 5dB unit, it will drain the juice out of your battery if not plugged into the mains.
Costs about 15 quid of ebay via China
Bigron
  • Witham, Essex
« Reply #11 on: 20 July 2014, 15:38:02 »
The one I suggested is £6.75 (£5.75 if you buy two) all inclusive and has a decent antenna; still from China, so you do have to wait a couple of weeks.....
Ron
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #12 on: 20 July 2014, 19:24:50 »
Ron
5dB versus 2dB gain, I know which one i'd use  ;)
Bigron
  • Witham, Essex
« Reply #13 on: 20 July 2014, 20:01:22 »
Only trying to help..... :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #14 on: 21 July 2014, 12:56:35 »
As we all are Ron
Just giving the bloke some options  :)
