Pages: [1] 2 3  All   Go Down
Author Topic: Caravan Electrics Problem  (Read 8451 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« on: 22 July 2014, 06:49:51 »
Pin 10 on the 13 pin socket is only shoving out 1 volt.
Pin 10 is the feed to the fridge.
Any ideas welcome please.
I like red cars
Re: Caravan Electrics Problem
« Reply #1 on: 22 July 2014, 08:02:25 »
It usually means a crappy joint where they have probably used horrible scotch blocks to fit the wiring.
Pop it round one evening if you want and I can take a look
« Reply #2 on: 22 July 2014, 09:29:34 »
Is the engine running ?? Fridge power only supplied by an ignition controlled relay (or should be) ... so I'd check the voltage on the INPUT to the relay, then the output connector with the output disconnected, simply to check the relay .. if thats OK then work down the wiring as Mark says.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #3 on: 22 July 2014, 14:20:28 »
Cheers Mark, I'll give you a ring :y
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #4 on: 22 July 2014, 14:21:31 »
Running @ 2000 revs.
I like red cars
« Reply #5 on: 22 July 2014, 17:34:46 »
As DTM says, usually a piss poor install I'm afraid AA.  On the upside, looks like he'll do it properly for you :y. Another example of OOF at its best :y
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #6 on: 22 July 2014, 17:42:44 »
Can't argue with that - even though I'm Omegaless ;D
I like red cars
« Reply #7 on: 22 July 2014, 17:44:14 »
Broocie, Kevin and I are the only Admin Team members driving Omegas as our primary cars now ;D
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #8 on: 22 July 2014, 17:45:31 »
But for how much longer?
I like red cars
« Reply #9 on: 22 July 2014, 19:26:17 »
I still very much enjoy driving ours.....sadly second place to the zafira for day to day use though these days.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #10 on: 23 July 2014, 06:47:02 »
Don't get me wrong, I also enjoyed Omega ownership, just wasn't suitable for my towing needs.
I like red cars
« Reply #11 on: 23 July 2014, 20:48:10 »
Sorted, another piss poor install by a so called professional who's twisted main power connections together and used scotch blocks
    • 530D M Sport, 330i Coupe
« Reply #12 on: 23 July 2014, 20:53:16 »
Sadly, of the three tow bars I've removed from various Omega's, every single one had twisted together wires. Can nobody use a soldering iron and heat shrink tubing if they haven't got the manufacturers connector?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #13 on: 23 July 2014, 22:24:03 »
That cheeses me off too,it's often quicker to do it properly in the first place :-\
other rides
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #14 on: 24 July 2014, 05:42:22 »
Big thanks Mark for sorting it out for me :y
I like red cars
Pages: [1] 2 3  All   Go Up
