Clanky plumbing
Started by Sir Tigger KC, 31 July 2014, 12:18:08
I've been getting a house I have ready for new tenants and noticed while cleaning that when turning the cold tap off in the bathroom basin, the pipes under floor are banging.  :(
So I guess a pipe clip has come loose and the pipes aren't secured as well as they should be?  ::)  :-\
Quote from: Sir Tigger on 31 July 2014, 12:18:08
Exactly how much property do you own, Mr Wealthy?......... ;D ;)
Quote from: Doctor Opti on 31 July 2014, 12:33:09
No where near as much as you Mr Wealthier!  :P  ;D
Quote from: Sir Tigger on 31 July 2014, 12:52:29
Far more than you do Mr piss poor!  :P  ;D
Fixed that for you. :y :y
A man of your means can certainly stretch to a polish plumber. ;D
Quote from: Doctor Opti on 31 July 2014, 13:07:51
A man of your means can certainly stretch to a plumbing polisher. ;D
Do you mind, I'm having my lunch :o
4x4
Is it on just 1 tap or several,could be tap insert needs regreasing or replacing,or as said a clip has come loose.
Quote from: 4x4 on 31 July 2014, 18:08:55
It does it a bit on the kitchen tap as well but not as bad, so I'll try that first as I don't really want to rip up the carpets and floorboards...  :-\
Thanks!  :y
4x4
If its the hot water side and you have a tank in loft or tank and cylinder together could be the ball valve
Gaffers
I thought that this thread would somehow be about a medical issue ::)
Quote from: 4x4 on 31 July 2014, 18:20:28
No it's the cold and on a combi!  :y
Quote from: Monsieur Guffer on 31 July 2014, 18:20:54
Ha ha yes I thought more people would have a look if they thought I had problems with my waterworks!  ;)  :D  ;D
Tony H
Commonly known as "pipe hammer" can be a absolute sod to cure. First port of call is to make sure the pipes are firmly secured at short intervals which should cure the problem, if not you will have to dig a little deeper I.E. ballcocks, valves etc.
4x4
Quote from: Sir Tigger on 31 July 2014, 20:19:24
In that case i would go with removing tap insert,remove circlip,knock the spindle through,unscrew,remove old grease ,then regrease with silicon grease,screw spindle in all the way,insert back into the body,give circlip a quick squeeze together and refit,then test.
Terbs
Sometimes, air in the system causes this. We bled our system through, and after a load of air came through, hissing and spitting, all was once more quiet  :y
chrisgixer
