Author Topic: shear bolts  (Read 2474 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
shear bolts
« on: 02 August 2014, 07:02:41 »
Anyone know the correct size of shear bolts that hold ignition barrel to the steering column tia  :y
sam
Re: shear bolts
« Reply #1 on: 02 August 2014, 07:54:46 »
Didn't think the barrel was bolted :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: shear bolts
« Reply #2 on: 02 August 2014, 08:08:34 »
barrel isn't. But the piece that holds the barrel, steering lock, is held onto the column with two shear bolts.
Think they be dealer only,unless you have a good fastner place local. Think theym6.
can be removed with a good dot punch,by tapping undone, and put back in the same way,fiddlee but doable.
Hoof'land storeman.
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: shear bolts
« Reply #3 on: 02 August 2014, 10:24:37 »
I think there M8 i think?
biggriffin
Re: shear bolts
« Reply #4 on: 02 August 2014, 15:41:55 »
You could just use std Allen bolts of the right length.
Hoof'land storeman.
kevinp58
  • kent
    • 2002 3.2 elite
Re: shear bolts
« Reply #5 on: 02 August 2014, 16:39:29 »
Usually steering lock bolts are 8MM  :y but never done a omega.  :-\
samrey4u
  • norwich
Re: shear bolts
« Reply #6 on: 03 August 2014, 19:23:03 »
thanks for all the reply guys ever helpful as always :y
sam
Page created in 0.07 seconds with 16 queries.
