Pages: 1 [2] 3  All   Go Down
Author Topic: slave cylinder  (Read 5274 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: slave cylinder
« Reply #15 on: 07 August 2014, 10:42:18 »
You guys are right. Not wanting to strip it for a slave cylinder so will just replace all  :y
How much are they, Davie? I've never done an omega clutch (watched one be done). Normally a new one comes with the clutch kit for things like fords etc  :-\
RIP Paul Lovejoy
Re: slave cylinder
« Reply #16 on: 07 August 2014, 10:47:15 »
LUK kits are either rep set: friction plate/pressure plate, or rep set pro: friction plate/pressure plate/slave cylinder (including release bearing). So the price difference is misleading. You can only buy the release bearing as a separate component from Vauxhall, and I cannot fathom why LUK won't supply it with the basic kit :-\
Webby the Bear
  • Northampton
Re: slave cylinder
« Reply #17 on: 07 August 2014, 10:52:25 »
Very strange. Whats the diff in price between the 2 kits out of interest?
RIP Paul Lovejoy
Re: slave cylinder
« Reply #18 on: 07 August 2014, 11:02:46 »
I don't recall :-[ the last clutch I bought came from Vauxhall...
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #19 on: 07 August 2014, 11:07:07 »
Cheapest i have found was 91 quid for clutch and pressure plate or 170 quid for same with a slave cylinder. Found a clutch on ebay supposing to increase torque is this correct??
Re: slave cylinder
« Reply #20 on: 07 August 2014, 11:24:59 »
Don't change the slave, you could potentially be fitting a part of unknown quality compared to the OE item which is known to be bullet proof.
Do change the release bearing which clips into the slave cylinder end (most base clutch kits come with this but if not, it can be bought separately)
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #21 on: 07 August 2014, 11:26:40 »
So best clean up slave. And go pressure and clutch plate?
Re: slave cylinder
« Reply #22 on: 07 August 2014, 11:41:30 »
Pressure plate, friction plate and release bearing  :y
Re: slave cylinder
« Reply #23 on: 07 August 2014, 11:43:58 »
This being as important as the other two parts :y
My LUK slave is on its second clutch and about 140k, with no concerns fwiw.
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #24 on: 07 August 2014, 11:46:19 »
Will do guys. Clutch plate, pressure plate and release bearing :y
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #25 on: 07 August 2014, 15:50:50 »
Cant find a release bearing anywhere. Only concentric slave, plate and pressure plate. Can find a release bearing for older cars. Sorry  :-[
Re: slave cylinder
« Reply #26 on: 07 August 2014, 15:54:08 »
Try Vauxhall :y Charles Warner in Lincoln might be a good place to start...
As I said earlier, pattern slaves include the bearing, but they won't sell them separately ::)
« Last Edit: 07 August 2014, 15:56:27 by Taxi Al »
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #27 on: 07 August 2014, 15:58:04 »
My car has the big green hydraulic thing in the box is that meant to have a release bearing on top? When i took it apart. It had dual mass flywheel. Clutch plate. Pressure plate then that green part. Sorry if im a breast al
Re: slave cylinder
« Reply #28 on: 07 August 2014, 16:22:11 »
Bearing lives on the end of the green thing... Should simply pull off, and it looks like a, um, er bearing ::)
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #29 on: 07 August 2014, 16:25:56 »
Am going for a pull at my bearing :-X
Pages: 1 [2] 3  All   Go Up
Page created in 0.233 seconds with 16 queries.
