Pages: [1] 2 3  All   Go Down
Author Topic: slave cylinder  (Read 5218 times)
davieboy0312
  • wishaw
    • 3l V6 saloon
slave cylinder
« on: 06 August 2014, 20:32:14 »
how bullet proof are the clutch slave cylinders don't want to refit the old one if prone to failure or am I better just getting a new one while box is off anyway?
Re: slave cylinder
« Reply #1 on: 06 August 2014, 20:43:16 »
You already know the answer :y
At the very least, replace the bearing :y
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #2 on: 06 August 2014, 20:54:52 »
bearing has been done didn't have a problem with clutch before removal slave looks ok though. best not take a chance
Re: slave cylinder
« Reply #3 on: 06 August 2014, 21:16:16 »
Ok, I have to ask...
Why is the box off it the clutch is sound?
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #4 on: 06 August 2014, 21:18:24 »
for powder coating candy red mate. plus the dual mass flywheel was fubar
Re: slave cylinder
« Reply #5 on: 06 August 2014, 21:24:27 »
Then you want to be changing the clutch too :y
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #6 on: 06 August 2014, 21:26:05 »
yea already got the flywheel fitted to block today. need the rest now.
chrisgixer
Re: slave cylinder
« Reply #7 on: 06 August 2014, 21:38:08 »
One wonders, has Al been candy appled as well?
Actually I'm off before the obvious happens ;D ;)
Re: slave cylinder
« Reply #8 on: 06 August 2014, 21:53:44 »
Candy apple is more Dazzles' colour ;D
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #9 on: 06 August 2014, 22:00:46 »
well by the end of September whole car will be that colour
Re: slave cylinder
« Reply #10 on: 07 August 2014, 08:25:40 »
In all the years, I am yet to see a failed slave cylinder on the Omega (unlike a few FWD units from certain manufacturers)
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #11 on: 07 August 2014, 09:16:19 »
So change clutch and pressure plate and old slave should be fine?
Re: slave cylinder
« Reply #12 on: 07 August 2014, 10:27:11 »
Only if you change the release bearing... if that fails, it will destroy everything in the bellhousing.
But whilst you're in there, you might as well change the lot :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: slave cylinder
« Reply #13 on: 07 August 2014, 10:30:49 »
Thing is look at what you have to go through to get at it again. Change everything imo  :y
RIP Paul Lovejoy
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: slave cylinder
« Reply #14 on: 07 August 2014, 10:38:41 »
You guys are right. Not wanting to strip it for a slave cylinder so will just replace all  :y
Pages: [1] 2 3  All   Go Up
