Removing data from broken iPhone 4
Started by JamesV6CDX, 26 September 2014, 11:53:35
My old iPhone 4 has broken. The battery port had de soldered itself from the circuit board (I guess it's the motherboard)
I want to pop it on eBay for spares. Is there any way I can wipe the phone first?
I can't get iTunes to talk to it due to no battery input and it's all to small for me to solder a port on
I have nothing questionable on there but if someone got into the phone they'd find saved passwords etc and would work out my address and occupation via various texts if they looked hard enough
It has a code to open the phone but no idea how secure that is or if it can be bypassed.
In short any advice on wiping it or if anyone could see my data please?
If it's not possible to make it secure I will just destroy it rather than take the risk :y
use the find my iphone app to remotely wipe?  (from another phone or via icloud.com)
Microwave it... twenty seconds should see it just about done :y
Gaffers
Quote from: Jimbob on 26 September 2014, 12:03:20
That would still need power on the device and it sounds like there is none :(
plym ian
cnj
why not repair it, I phone 4s still fetch reasonable pennies and I believe you can watch it being done on you tube !
Blueron
Charging connector ribbon on ebay about £4.  No soldering required.Just replaced mine on iphone 4 ,all works fine again.Quite fidley but I followed the youtube vids and it is doable.Good luck hope you sort it.
Blueron
Sorry just reread.Its you battery connector not your charging port.My Mistake.
If its only the batt connector, can't you just plug it in to gaytunes, and do a full factory reset?
Personally, I'd avoid phones on egay. That's just a little bit daft, young'un.
tigers_gonads
Plenty of spare parts available for the iphone 4 / 4S
Strip it (fiddly I know) and replace whatever parts needed  ;)
Presumably he's already stripped it to know what the fault is...  ...else I'd be shoving in a £5 battery, and seeing if that fixed it ::)
tigers_gonads
Quote from: TheBoy on 27 September 2014, 10:24:30
::) Its a fair cop guv  :-[ ;D
