Author Topic: Heated seats not working  (Read 3059 times)
woolley11
  • York
    • 3.0 MV6 auto
« on: 15 October 2014, 20:31:21 »
The leather seats in my MV6 don't warm up. The wiring/fuse must be ok as I replaced the cloth seats which did warm up.
I assume the heat pads are at fault on the leather set. Can these  be obtained ? I would think I would have to remove the seats to get at them.
Any pointers?
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
Re: Heated seats not working
« Reply #1 on: 15 October 2014, 21:16:23 »
PFL or FL?
The element in the leather seats are not replacable, it has to be repaired.
woolley11
  • York
    • 3.0 MV6 auto
« Reply #2 on: 16 October 2014, 19:14:26 »
It's a pfl model
Is it a job for an auto electrician then?
Omega 3.0 MV6 pfl
woolley11
  • York
    • 3.0 MV6 auto
« Reply #3 on: 16 October 2014, 19:21:36 »
It's a pfl model
Omega 3.0 MV6 pfl
« Reply #4 on: 16 October 2014, 19:27:16 »
With leather seats, the heater pads are stiched into the leather, with cloth seats the pads are separate...
If you can find a rough set of pre/mid facelift cloth CDX/Elite seats with working heaters then you could remove the pads and fit them to your leather seats. They won't be as effective due to the extra layer, but they will work. Stripping seats is not for the faint hearted though... fiddly, and they're bastid heavy ::)
woolley11
  • York
    • 3.0 MV6 auto
« Reply #5 on: 16 October 2014, 21:48:28 »
Seems like I'll have to put up with them not working - sounds a right ball ache  :(
Omega 3.0 MV6 pfl
« Reply #6 on: 16 October 2014, 22:36:11 »
Remove the seat & inspect the heater element ..... more likely to be the base seat element that has burnt somewhere - you might be lucky & be able to cut the burnt bit out of the seat heater. I fixed my Omega & Senator before it by doing just that.  :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #7 on: 17 October 2014, 09:51:41 »
I'd say worth an investigate. It's one of those jobs that's time heavy, not wallet heavy, if you follow. If you can't see anything, them stretch everything back in place and you've not lost anything.
« Reply #8 on: 17 October 2014, 14:29:34 »
It's one of those jobs that's time heavy, ....
.... and the seats are bloody heavy too  :y :y :y
« Reply #9 on: 17 October 2014, 14:31:17 »
Took both ones out last week, as it goes. I don't know what you mean...
-Sent from Spinal Injury Ward of Grimsby Hospital-
« Reply #10 on: 17 October 2014, 14:33:05 »
 ;D ;D ;D ;D ;D ;D
woolley11
  • York
    • 3.0 MV6 auto
« Reply #11 on: 18 October 2014, 13:38:20 »
Thanks guys
Omega 3.0 MV6 pfl
