Author Topic: Aircon leak at high pressure filling point ball bearing  (Read 2201 times)
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
« on: 25 October 2014, 08:54:00 »
I took my car to ATS to have a recharge and antibac bomb with an amazon voucher I had. They called to let me know that there is a leak at the above position. They are going to give me a price for having this section of pipe repaired. However, I was just wondering if this might be something I could possibly do myself?
serek
  • huntingdon
    • 3.2 mv6
Re: Aircon leak at high pressure filling point ball bearing
« Reply #1 on: 25 October 2014, 09:41:11 »
sound like your HP valve leak, dont need replace any section of pipe just valve
EDIT: how to http://www.omegaowners.com/forum/index.php?topic=124057.0  :y
« Reply #2 on: 25 October 2014, 18:41:04 »
.... They are going to give me a price for having this section of pipe repaired.  .....
For some reason there seems to be a common misconception that the valve is part & parcel of the pipe, as Beserkerboy says, the valve itself is very easily replaced ...... just support the boss on the pipe as you undo the valve or theres a good cjance that the pipe will be damaged. The hardest thing is getting your local Vx dealer to order the correct valve.
« Reply #3 on: 25 October 2014, 19:09:31 »
Aint that so , bloody useless  :(
ted_one
« Reply #4 on: 25 October 2014, 19:23:57 »
The problem  with ATS that they will not fit parts supplied by the customer,had the problem when I asked them to fit new rear track rods when they found mine were seized during a four wheel alignment....still not done yet ::)
DrAndyB
  • Neston / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #5 on: 25 October 2014, 19:26:57 »
Yep, got my HP valve changed last month when AC finally stopped after 14 years  :'(
New valve, vac out and new coolant and cabin is ICE cold now  :y
The link posted by Serek was I how got VX Stealer to get the right valve.  I think there was also a exploded diagram of the AC System with part numbers listed somewhere on OFF too ?
I think the part number may have changed but they were claimed to be standard ones and I could probably find the VX invoice if needed for part number  :y
berserkerboy
« Reply #6 on: 26 October 2014, 19:23:02 »
Okay folks thanks for the info. Interesting to see what ATS say but in any case will get the part myself and fit once I am sure there is no gas left in the system.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 26 October 2014, 19:58:12 »
The HP valve can be removed,then cleaned with carb cleaner. The gunge up with dye and refrigerant  :yesterday
Hoof'land storeman.
berserkerboy
« Reply #8 on: 27 October 2014, 20:55:52 »
ATS quote: £220 + VAT message left on answerphone. Apparently the valve is soldered in...I think not. Carmarthen stealer price for the valve  £4.19 + VAT. Unfortunately, there is gas left in the system. When I unscrew the plastic cap I can hear it leaking out. Presumably ATS could safely pump it out for me to replace the valve and then refill?
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #9 on: 27 October 2014, 21:02:31 »
Yep,  my local place charges most people a small fee for doing the vacuum but then refunds it when you go back for the refill, not sure about ATS.
The valve size seems a bit odd and some have issues getting a spanner to fit, just make sure you hold the pipe with a spanner while undoing \ doing up the valve.
If it aint broken, you aint trying hard enough
« Reply #10 on: 27 October 2014, 22:24:20 »
15mm for the valve, 17mm for the boss it screws on to.  :y
biggriffin
« Reply #11 on: 28 October 2014, 08:17:09 »
Also in the maintenance section ::)  ::)
Hoof'land storeman.
Page created in 0.025 seconds with 16 queries.
