Author Topic: LPG fit - last hurdle  (Read 1051 times)
« on: 25 June 2008, 20:51:39 »
More progress today...
Hole drilled in rear panel, filler assembled and fitted. Looks good.
First fill of LPG - filled fine, no leaks. The tank only took 43l which is a little less than I hoped but hey it's not too bad.
Loom fitted and all electrical connections made/soldered.
Everything tidied up as much as possible.
Cables routed into cabin, switch mounted in dashboard and buzzer connected.
Laptop connected, all software parameters set. I can see correct RPM and Lambda values so I've spliced the right wires!
Hopefully the only jobs for tomorrow is a quick scuttle mod and a mount and fit of the vaporisor, and I should be cooking on LPG  :D
Re: LPG fit - last hurdle
« Reply #1 on: 25 June 2008, 20:52:26 »
Fair play!
Do we get to see it at the weekend?
« Reply #2 on: 25 June 2008, 20:53:25 »
Fair play!
All being well...
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
« Reply #3 on: 25 June 2008, 20:53:44 »
well done matey  :y :y :y  a day well spent  ;)
« Reply #4 on: 25 June 2008, 20:54:14 »
Fair play!
All being well...
Good, looking forward to catching up with you all again  :y
JueV6
  • Kent
« Reply #5 on: 25 June 2008, 21:47:23 »
Well done James, I don't know if my pics were of any use to you in the end. :y
« Reply #6 on: 25 June 2008, 21:53:01 »
Good work mate ... hope the vap arrives ok .. you deserve it !!!
