Thank you Marks DTM Calib
Started by TheBoy, 16 November 2014, 20:27:34
For a spot of welding, identifying a possibly/likely reason it uses almost as much coolant as fuel and swapping that pesky seized caliper that I had failed to undo a week or 2 ago :y
Top guy, as always :y, and thanks to Mrs DTM for keeping me in tea all day :)
Quote from: TheBoy on 16 November 2014, 20:27:34
How was the biscuit arrangement?
Quote from: Taxi Al on 16 November 2014, 20:29:49
Hmmm, yes, that's a good point, there wasn't a biccie arrangement, I strike her off the xmas card list :P.  But pizza and chips went down well :D
Absolutely nowt to grumble at there then :y
chrisgixer
How bad was the rust? Bad enough to need welding obviously, but as deep as expected?
Pretty localised, cut out and a 3mm plate welded in.
Thanks for the labouring this afternoon whilst I threw a few blocks down
Good to see you doing a bit to help out while you were there too!
I have photographic proof!
chrisgixer
What what? Labouring? Blocks?
Has Master started without us?
Quote from: chrisgixer on 16 November 2014, 20:41:52
It had an adviso a couple of years back, about time it was sorted  ;D  :-[
As it happens, once tapped out with an educating stick, not too bad, but was holed.  Mr DTM made light work of it :y
Quote from: Marks DTM Calib on 16 November 2014, 20:47:10
You are, of course, most welcome. Can't beat a little bit of good, honest graft :y
Quote from: TheBoy on 16 November 2014, 20:52:04
[/highlight]
Good for the Heart, good for the Soul & good for the Back! :y
Not sure if it's any good with Gout though! :-\ ;D ;)
Webby the Bear
Oof rises again. How was the water pump diagnosed ? Presumably finding a bunch of coolant peeing down on the splash tray thingy?
RIP Paul Lovejoy
Quote from: Webby the Bear on 16 November 2014, 21:44:17
A telltale sign of dampness on the cam cover made MDTM slacken the aux belt showed that the pump spindle was like a cock in a sock.
Webby the Bear
Quote from: TheBoy on 16 November 2014, 21:53:07
:o :o :o
Was there no noise?
Excellent find though!
RIP Paul Lovejoy
Pretty easy to spot the water pump issue, coolant was appearing a lot on the front of the sump area and running down the side.
A tell tail sign of wetness on the cam cover around the water pump
Then a case of check for play......of which there was plenty.
We also lifted the plenum to inspect the valley and stat for leaks etc and all was nice and dry there, there may be further leaks potentially but, the pump needs replacing as a first port of call.
As is always the first port of call with a water leak......use your eyes and check around the system for signs of water.
