Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14   Go Down
Author Topic: Welding Blog  (Read 45354 times)
Re: Welding Blog
« Reply #120 on: 28 November 2014, 11:41:18 »
.. and an auto-dimming mask would be a great addition to your arsenal, IMHO. Just got a cheap one but it makes all the difference IMHO.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Welding Blog
« Reply #121 on: 28 November 2014, 12:01:08 »
Completely agree Kev... I don't know if you read my post about when I ordered it but I was looking for an auto mask as you guys suggested. Accidentally brought a non-auto mask. Cos I got the words ''adjusting'' and ''Auto-dimming'' confused. . . they both start with 'A' at least  ::)
Its so difficult to put the visor down and its all black.... then weld where you want.
RIP Paul Lovejoy
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
Re: Welding Blog
« Reply #122 on: 28 November 2014, 12:14:25 »
Im reading this 'blog' every day and really enjoying the trials and tribulations your going through, as I'm in the same boat as you are...
I had to buy a MIG to weld my Omega to get it through its last MoT as the stick/arc welder I have was just too harsh for the metal I was attempting to patch up...
The MIG made it sooo much easier to sort out it's MoT... Gonna need it again for the next, but will have a lot more experience this time...
I won't say I can weld, I wouldn't call myself a 'welder' BUT I can join 2 pieces of metal together using the welding process LOL
I actually enjoy welding, I will admit I don't mind if I need to weld something, I usually make an excuse to do some sort of welding..
I have an auto dimming mask, which is adjustable for how dark it gets, which I find very handy... Compared to when I first did any sort of welding when I was a kid (about 18) and welded without a mask, I had a mask but it got in the way... Anyhoo the day after I couldn't see, had horrible sunburn and drove myself to the hospital (stupid I know) they gave me some drops and pain killers which helped but I had to see an optician as ever since Iv been sensitive to bright lights because I burnt my retina... Not fun... I look back now and laugh but Iv never once welded without a mask...
D.I.L.L.I.G.A.F...
Re: Welding Blog
« Reply #123 on: 28 November 2014, 13:07:43 »
Seen these  :-\  Mask
I been looking at an Arc welder myself  :y
Re: Welding Blog
« Reply #124 on: 28 November 2014, 13:11:34 »
Arc welding is fine for structural lumps but bloody hopeless on cars and the like unless its nothing more than bodging a patch on.
And there even worse when it comes to thin plate and panels.
For me personally ARC welding only has a single advantage and that is you can weld outside with it (so good for gates etc)
Re: Welding Blog
« Reply #125 on: 28 November 2014, 13:14:01 »
What about welding in tight spaces though , mig cant do that  :-\ Ive seen some video of thin plate welding with Arc
Mr webroot , you know you can get flux core wire for mig then you wont need to keep buying gas  :)
« Last Edit: 28 November 2014, 13:18:32 by Emd »
Re: Welding Blog
« Reply #126 on: 28 November 2014, 13:33:34 »
Welding in tight spaces is harder with Arc, particularly with a fresh rod.
And welding thin stuff with ARC is a mare, easiest way to distort a panel or suffer blow through.  :y
I do all three types, MIG, ARC and TIG.....and its very much horses for courses.  :y
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #127 on: 28 November 2014, 15:12:21 »
Glad you're enjoying it mate and all the best for your welding  :y
That's a really good point. When can you call yourself a welder? lol technically I suppose I can having welded two pieces of metal together  ;D but I'd say I know 5%.... so still got 95% to go  ;D
Re the mask. that would suck. you still get the eye sensitivity?  :o :'(
RIP Paul Lovejoy
Re: Welding Blog
« Reply #128 on: 28 November 2014, 15:15:47 »
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #129 on: 28 November 2014, 15:16:28 »
Steve, thanks for that link. Don't care about design of mask. Just want a ''good 'un''  :y
Re the flux core... I did consider it. Is it even compatible with my machine? I was told by a few people not to bother. Can't remember the reason why  :-\
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #130 on: 28 November 2014, 15:18:30 »
When you're coded ;) http://www.hgcodedwelding.com/Articles/how-do-we-define-coded-welding-or-code-welding
Whilst I'd love to flash a welding cert. at people that's definitely not for me. I'd much prefer to say ''yeah, I taught myself''......with help from OOF of course  ;) ;) ;)
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
Re: Welding Blog
« Reply #131 on: 28 November 2014, 18:18:08 »
you need to reverse polarity of gun-2 wires inside welder near wire spool--and dont bother---rusts very quickly and harder to do as heat is more local -giving distortion of metal being welded---not good for bodywork
lloyds and british federal :y thats mine
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #132 on: 28 November 2014, 18:27:38 »
Knew there was a reason for not using it. Just couldn't remember what.
Yep, I know the leads you're talking about.  . . Won't touch them!  ;D
My first bottle of gas is still working  :o woulda thought that woulda run out by now. Got three back up double capacity bottles just in case though  :)
Re mig welding in tight spaces. . . Interested to know why it wouldn't work. . . Obviously depending on what your definition of tight spaces is. E.g. I have seen many vids where people repair chassis parts using mig.
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
Re: Welding Blog
« Reply #133 on: 28 November 2014, 18:32:25 »
you can build a chassis mate--but you need good weld penetration--otherwise risky and tight space? if you can get gun into it and see--then not a problem--try dummy run with gun first--ie not welding-just checking movement/room etc
Re: Welding Blog
« Reply #134 on: 28 November 2014, 18:57:48 »
Flux core will smoke out your garage pretty quick though  ;D + splatter issues ...
Just been watching flux core gas shield  :D
« Last Edit: 28 November 2014, 19:00:01 by Emd »
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14   Go Up
