Pages: 1 2 3 [4] 5 6 7 8 9 10 11 ... 14   Go Down
Author Topic: Welding Blog  (Read 47767 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Welding Blog
« Reply #45 on: 22 November 2014, 20:39:56 »
Just gone and double checked and the wire is now coming out spot on. I undid the spool nut slowly and didn't really have any affect....and it was quite loose-ish already. so not gonna concern myself with it.  :y
RIP Paul Lovejoy
Re: Welding Blog
« Reply #46 on: 22 November 2014, 20:53:58 »
It has to be adjustable to allow for a variety of wire thicknesses :y
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #47 on: 22 November 2014, 21:09:09 »
Thanks Al, the one I'm talking about though is the nut holding the spool on.  :y
RIP Paul Lovejoy
Re: Welding Blog
« Reply #48 on: 22 November 2014, 22:27:34 »
 :y still affects the overall wire tension...
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #49 on: 22 November 2014, 22:54:00 »
oh ok fair enough. cheers mate  :y
incidentally.... the little disc with the grooves in.... mine has one for 0.6mm and one for 0.8mm. can I get one for say 1mm thickness? just out of interest  :y
RIP Paul Lovejoy
Re: Welding Blog
« Reply #50 on: 22 November 2014, 23:56:20 »
Possibly,  have a look at the Clarke catalogue... 135amps might not be man enough for 1mm cable, but I make no claim to know that for sure :-[
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #51 on: 22 November 2014, 23:58:16 »
Will do, cheers Al  :y
RIP Paul Lovejoy
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Welding Blog
« Reply #52 on: 23 November 2014, 00:07:00 »
.6 wire will be plenty enough for that welder,the wire feed will strugglevwith .8 and 1.0 is a no no,need a heavier machine for that :y
other rides
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #53 on: 23 November 2014, 00:10:35 »
Thanks for confirming mate  :y :y :y
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
Re: Welding Blog
« Reply #54 on: 23 November 2014, 16:37:28 »
Soon be able to tackle stuff like this then mate  :y :y
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #55 on: 23 November 2014, 16:42:12 »
So watched the F1 for a bit keeping an eye on the weather and it stopped raining for good about 2. So gave the welder a blast. :)
I measured the thickness of the metal to be welded. just under 1mm so set up the welder as per the below settings:
Gas regulator set to 4 as recommended.
First weld, burned straight through  ;D
I was keeping an ear out for the sound and it was ''cracking'' as opposed to a continuous buzz. So I turned the wire speed down and that seemed better.
Please don't mock  ;D these are my first attempts at running beads...as you can see there are some burn throughs. but after playing around with the settings there were a few that I did that I thought ''hmmm, not bad'' but in honesty most are terrible.
Second piece of metal. This frustrated me cos I just couldn't seem to get the setting right. it was spattering, burning through and cracking.
Then finally as I had about 30 mins of light left I decided to try and weld two pieces together.... this was even worse. my first weld went brown  ??? ??? ??? ??? I had a think and I presume these are oxidised cos the gas has run out? but either way absolute shit  ;D ;D ;D ;D
to be fair I tried on loads of different settings and never could get it quite right apart from a couple of times.
then I thought.... I was outside (although in an alcove in the garden to try and get out of any wind)
but im a persistent bear and will keep going/ next attempt...Thursday :)
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
Re: Welding Blog
« Reply #56 on: 23 November 2014, 16:47:02 »
turn wire speed down a touch and try supporting your welding hand ---not bad mate-seen worse---and dont tighten regulator too much on gas bottle-for some reason they dont like it--remember i showed you with my sip welder(like yours) :y :y and keep at it mate :y :y :y :y :y
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #57 on: 23 November 2014, 16:49:07 »
Thanks Symes.  :y
Would you agree I ran outta gas though when I tried to join those two pieces? And is being outside not helping?
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
Re: Welding Blog
« Reply #58 on: 23 November 2014, 16:52:59 »
outside-make a wind brake - or move yourself so that wind do not blow gas shield while welding --and read what i said about regulator ;) ;)
Webby the Bear
  • Northampton
Re: Welding Blog
« Reply #59 on: 23 November 2014, 16:55:58 »
Thanks mate.
Yeah I made sure I didn't tighten it too much. and also I could hear the gas coming out as I pressed the trigger  :y
RIP Paul Lovejoy
Pages: 1 2 3 [4] 5 6 7 8 9 10 11 ... 14   Go Up
