Rear brake pads
Started by rockindave, 06 December 2014, 08:00:42
rockindave
Hi all,might be a stupid question but are there any differences in the rear pads on the MV6 or are they all the same...Thanks in advance Dave
amba
Pads are all the same across the range/engine size.
On vented discs the securing pins are longer,so if yours are shot or badly rusted,be aware that they are difficult to get spares as I found out last year.VX order direct from Germany . :o
chrisgixer
Depends which mv6? Not all are vented.
Or specifically if vented or not depends on the appropriate length of pin and fitting kit. As amba. Pads same.
Quote from: chrisgixer on 06 December 2014, 09:00:34
Mine are vented.
chrisgixer
Quote from: Doctor Opti on 07 December 2014, 14:00:25
Mine are vented.
Is yours the same as the op's?
If the OP could advise which engine is in his vehicle it may assist in providing the correct answer.  :y
Pads are same across range at rear. The fitting kit varies, as 2.6/3.2 have vented discs (or should have - some bodgers retrofit cheaper replacements, which will eventually kill you), thus have longer pins and bigger spring.
Keith ABS
Give me a pm if you are still looking mate
Keith B
rockindave
It has vented discs I've got the pads now hoping to fit this weekend,thanks for all help guys
If you haven't done them before...
1. Lift car up.
2. Wheel off.
3. Drift the pins out.
4. Remove outboard pad.
5. Push outboard piston in.
6. Scrape all the muck out of the caliper.
7. Wipe some copper slip along the top and bottom edge of the new pad backing and either side of the shim, if present.
8. Fit new pad.
9. Repeat steps 4-8 on inboard pad
10. Refit pins/spring.
11. Refit wheel.
12. Drop car and tighten wheel nuts to 110Nm.
Repeat for opposite side :y
Sounds long winded, but takes less time to do than to type ;D
The reason is simple, if you remove both pads, then as you push one piston in, it will simply push the other one out, literally... Both messy and annoying.
By doing one pad at a time gives the second piston summat to push against, thereby keeping it in place :y
rockindave
Quote from: Taxi Al on 13 December 2014, 12:54:36
1. Lift car up.
2. Wheel off.
8. Fit new pad.
11. Refit wheel.
Cheers for that I'm doing them tomorrow  :y
biggriffin
Quote from: Keith B on 09 December 2014, 07:52:04
Keith B
Incoming  :)
Hoof'land storeman.
1. Lift car up.
2. Wheel off.
8. Fit new pad.
11. Refit wheel.
Which in reality means beating the shit out of the rusted in little turds with a large hammer and a nail. :)
 ;D I tend to use a proper drift and a club hammer... nails tend to bend, which is a pretty effective way to spend an afternoon in A and E ::)
Quote from: Taxi Al on 13 December 2014, 17:28:55
In the OOF guide a nail is used......so there. :y :y
