Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: What a crazy.... insane.....deluded way to throw away almost £4000.  (Read 12658 times)
Re: What a crazy.... insane.....deluded way to throw away almost £4000.
« Reply #45 on: 09 December 2014, 21:26:57 »
But thinking about it, you'll only be keeping it for 5 minutes so as long as it looks nice, I wouldn't worry too much!  ;D
« Reply #46 on: 09 December 2014, 21:40:16 »
No MOT......so chassis and outriggers may need replacing. I believe the anaemic 2.9 litre lump has gear driven cams......or is that the 2.8?
« Reply #47 on: 09 December 2014, 21:45:46 »
Chain driven, but variation on a theme... 12v pushrod lump :y
« Reply #48 on: 09 December 2014, 22:02:17 »
State of the art then.
« Reply #49 on: 09 December 2014, 22:17:03 »
If it's good enough for the Chevvy V8 it should be good enough for the Cologne lump ;D
« Reply #50 on: 10 December 2014, 10:37:39 »
The old 3 litre 'Essex lump' was far superior in my opinion. At least it had a decent dollop of low end torque.....bit breathless at higher revs though.
« Reply #51 on: 10 December 2014, 10:40:53 »
Zakspeed twin turbo Capri? Anyone? 8)
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
« Reply #52 on: 10 December 2014, 10:51:00 »
and a picture of this car?
« Reply #53 on: 10 December 2014, 10:54:13 »
As is the Cologne, IMHO. Neither engine has anything to give above 5,000 RPM, which is a bit of a shock if you expect it to just keep pulling like the GM V6 does.. Still, in a TVR it should be quite "adequate". ;)
Watch that chassis, though. If the spaceframe has rotted, you have a whole world of grief ahead.
« Reply #54 on: 10 December 2014, 10:54:58 »
Oh dear, it's a TVR :-\
How many do you get?
Finally.......But not a proper TVR, Al. :y :y :y :y :y :y
An S3 with the weedy 2.9 V6.
Waste of time bothering with that then.
A TVR's strong points are its raw power and handling.
Given that boat anchor you will get neither!  :y
« Reply #55 on: 10 December 2014, 10:56:55 »
Here do...
« Reply #56 on: 10 December 2014, 10:57:37 »
Kevin.....If possible I'm hoping to see the car today. As far as I'm aware the chassis and outriggers are the originals from 1992. It is also white, a colour I'm not too fond of.
« Reply #57 on: 10 December 2014, 10:58:20 »
Here do...
Is that a 280 Tasmin from the eighties?
« Reply #58 on: 10 December 2014, 11:00:06 »
Variation on a theme :y
I should add, or rather should I, that I used to deliver repair panels to the TVR service centre in Redhill... :-\
Not pretty :-X
« Last Edit: 10 December 2014, 11:02:15 by Taxi Al »
« Reply #59 on: 10 December 2014, 11:04:08 »
It certainly won't be quick, Mark. I believe the 2.9 has only 170 BHP. My 2.6 Omega has 178/180 depending on which publication you read.
Only weighs about 960 KG though.
Pages: 1 2 3 [4] 5 6   Go Up
