Author Topic: what other VX steel wheels ?  (Read 3209 times)
powerslinky
« on: 10 December 2014, 14:32:22 »
hi all
        I need to get another 2 steel wheels with tyres to temporarily  put on my project  omega ,
So will go to local breakers at the weekend  to find 2. They are just to keep the car mobile on the driveway while I refurb the alloys from the project omega.
Will 5 stud vectra wheels fit or any other model or even make ?
As said , just to keep car on 4 wheels  &  moveable . .  it won't be going anywhere near the road  ;)
TIA for any advice greatly recieved   :y :y
Re: what other VX steel wheels ?
« Reply #1 on: 10 December 2014, 14:36:22 »
Steelies from Vectra C will be perfect for your needs :y
powerslinky
« Reply #2 on: 10 December 2014, 14:38:35 »
 ::)  give us a clue Al .  . what reg will veccy C run from /to   :-[ :-[ :-[
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #3 on: 10 December 2014, 15:52:26 »
Any normal Vauxhall 5-stud car wheels are interchangeable. Offset is another issue, but the PCD is the same.
Note: This excludes Vivaro vans, Royales/Monzas/Mk 1 Sennys and VX220s and Monaro/VXR8, but I'm not counting these as 'normal' as you don't normally find these kicking around in your average scrapyard  :).
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 10 December 2014, 18:43:47 »
One of each in my favourite local yard  ;)
« Reply #5 on: 10 December 2014, 19:23:35 »
'52 - '59 :y
Not quite, the rebadged Korean and Japanese stuff varies and the newer cars have a pcd of either 115mm or 120mm, and Astraas are 50/50 for 4 or 5 stud ;D
« Reply #6 on: 11 December 2014, 09:21:32 »
'52 - '59 :y
I was giving the original poster the credit of intelligence that he'd be able to count the number of holes in a steel wheel.  :y
Also sincere apologies, yes the Insignia and latest Astra are now 'upped' to 115, not 5 x110. I was not aware of this. OP mentioned touring round his local scrappys looking for wheels, you must have more of these in your scrapyards round your way than we do.  :)
OP may find this useful
http://www.wheelfitment.net/vauxhall
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #7 on: 11 December 2014, 09:50:24 »
IIRC the Vec C runs from 2003 to 2014 then the Insignia started...
Vec C steelies will fit no problem, Im actually after a set to use as winter wheels...
Vectra B wheels do fit also but might need spacers...
D.I.L.L.I.G.A.F...
« Reply #8 on: 11 December 2014, 10:03:25 »
Yup, lots of different offsets to consider, but that's either sit down and work out how offsets work, and the mm you'll be moving the wheels in or out by -  or just fit them and see how it handles. Theres lots of talk about 'oooh, what if I go from 225 to 215 tyres.. will I skid off into a ditch and kill my family etc...' and to be honest, tyre width / offset etc isn't something you're going to notice in normal driving on the roads.
I'm not saying the offsets / track etc wasnt picked by specialist engineers, because it was, and it does affect handling, but as does a full tank of fuel, unevenly distributed load in the boot; but as I say, how much you're noticing this on roads, for me, I'd say not a lot. I'm on three 16s and one 15, with different sidewall profiles and width, and can't tell.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #9 on: 11 December 2014, 11:07:20 »
Please don't let anyone run into you, as your Insurance Co will immediately determine it was your fault! :y
« Reply #10 on: 11 December 2014, 11:45:38 »
.... I'm on three 16s and one 15, with different sidewall profiles and width, and can't tell.
He'd obviously only need to say he'd fitted his spare & was on his way to ATS  ;)
« Reply #11 on: 11 December 2014, 12:16:32 »
 :y Yup, got the matching alloy in the boot spare wheel well - I've got a good tyre in the back yard, only my friendly tyre changer bloke is currently in Thailand (thigh-land) at present!  :)
« Reply #12 on: 11 December 2014, 12:49:57 »
As the OP only requires the wheels to keep his chassis off the drive whilst the wheels are refurbished, none of the above applies :y
If it weren't the case I would have been at the front of the queue to explain how and why his actions were retarded ::)
And for reference the Insignia was launched in early 2009, not 2014 ;D
« Reply #13 on: 11 December 2014, 13:23:36 »
True, sir, but if I hadn't mentioned that different offsets do affect handling, someone would have mentioned it  :y :y so thought it better to be comprehensive  :)
« Last Edit: 11 December 2014, 13:30:18 by Diamond Black Geezer »
powerslinky
« Reply #14 on: 11 December 2014, 17:58:12 »
Thanks all . . . . I think I know what to look for now :y
Oh hang on  . . . is it   4 'oles  or   5 'oles :y :y :y :y :y :y :y :y
Page created in 0.015 seconds with 14 queries.
