Author Topic: Car not starting...  (Read 1540 times)
yt03
Car not starting...
« on: 12 December 2014, 21:22:58 »
Just went to start my car and it wouldn't fire straight away, the second time it did... Went and did a quick job and it did it again... What do you think?? Starter motor?? I've just spent £405 getting some jobs done :'(
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
Re: Car not starting...
« Reply #1 on: 12 December 2014, 22:18:07 »
Does the starter run as normal but engine wont fire, or is the starter dead? If starter runs normally get the codes read and suspect crank sensor. ( if v6 atleast)
chrisgixer
« Reply #2 on: 12 December 2014, 23:13:20 »
Cranking and not firing? Crank sensor.
See code reading in maintanance section index. You want the pedal trick. Count flashes. Look for 0335.
If present. New genuine sensor only, from a vx dealer only. Theory is the heat from the engine breaks them down over time. So expect the symptoms to get worse and eventually refuse to start completely.
Hope helps. :)
chrisgixer
« Reply #3 on: 12 December 2014, 23:14:42 »
yt03
« Reply #4 on: 13 December 2014, 07:57:06 »
This morning she fires straight away, thanks for your replys i will try have a look after work!!
powerslinky
« Reply #5 on: 13 December 2014, 11:13:34 »
Almost certainly crank sensor IMO . . .  as said above  replace with genuine GM only
yt03
« Reply #6 on: 13 December 2014, 14:58:13 »
Cheers big al, is it a job I can do myself I'm no fitter, but like getting dirty ;D
yt03
« Reply #7 on: 13 December 2014, 15:04:03 »
Just found a good thread on the maintenance section :y
What's this "pedal trick" I keep seeing people say?? Sorry for sounding dumb, just trying to learn  :-[
chrisgixer
« Reply #8 on: 13 December 2014, 15:08:06 »
Am I invisible these days or what? ;D
yt03
« Reply #9 on: 13 December 2014, 15:14:16 »
Not at all mate, just me being blind and failin to see the link on the link you gave me, sorry pal
