Author Topic: central locking  (Read 4656 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
central locking
« on: 04 January 2015, 12:30:14 »
My drivers side lock popup is not always popping up fully and I have to pull it up from the back door to get into the car. The inside handle operates ok. Before I pull the door card off is it the motor getting tired or just lubrication needed.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: central locking
« Reply #1 on: 04 January 2015, 13:57:33 »
You can always use the key, just ensure that the alarm is disabled ;D. I do the same thing with mine and as it is now a Cat C
i don,t think it,s worth doing until it goes completely tits up. :y
Re: central locking
« Reply #2 on: 04 January 2015, 14:02:15 »
Likely to be the motor. Get a replacement from breaker, then refurb your old one as a spare :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: central locking
« Reply #3 on: 04 January 2015, 15:33:14 »
I do have a spare and a couple that want refurb. I looked into this but could not find the micro switches needed. Any help on sourcing.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: central locking
« Reply #4 on: 04 January 2015, 22:35:52 »
Re: central locking
« Reply #5 on: 05 January 2015, 17:20:44 »
RS Components, Part #290-0463, http://www.omegaowners.com/forum/index.php?topic=90642.0
RS are a royal PITA to deal with if you only want a couple of items. Farnell/CPC are easier, but there's lack the tabs, so need a spot of glue
Re: central locking
« Reply #6 on: 05 January 2015, 17:21:17 »
And given postal costs, not worth OOF buying a shed load for the shop :(
Shackeng
  • Ramsbury
Re: central locking
« Reply #7 on: 05 January 2015, 18:57:37 »
Had no problem when I ordered 2 last year. :y
Shackeng
  • Ramsbury
Re: central locking
« Reply #8 on: 05 January 2015, 18:59:27 »
Does that mean the shop is ordering again? If so two OOF stickers please, and two tax disc size ones as well.
Cheers 8)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: central locking
« Reply #9 on: 06 January 2015, 14:27:39 »
I have taken my dud spare motor apart and  now have to try to get it desoldered.Do I assume that it is the white switch which is at fault. The one on the car at the moment lifts the knob up but not quite far enough would this mean that the switch is faulty or the motor mechanism. ???
  • Online Online
Re: central locking
« Reply #10 on: 06 January 2015, 14:34:40 »
.... The one on the car at the moment lifts the knob up but not quite far enough would this mean that the switch is faulty or the motor mechanism. ???
Could be either. My car did similar & a good lub'ing sorted it for years .... the motor was changed at a later date though  ???
Shackeng
  • Ramsbury
Re: central locking
« Reply #11 on: 06 January 2015, 17:15:43 »
Full info on here: http://www.omegaowners.com/forum/index.php?topic=90642.0
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: central locking
« Reply #12 on: 07 January 2015, 11:27:24 »
Can the microswitch be tested without putting the whole unit into the car.Is it a simple make and break on the contacts. Anybody got any spare microswitches for sale. As the postage from RS is so high I thought about buying half a dozen and keeping them for OOFs when they need them .
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: central locking
« Reply #13 on: 07 January 2015, 11:32:18 »
Working on it . Give me a few days  :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: central locking
« Reply #14 on: 22 January 2015, 19:50:17 »
I took out a microswitch from a central locking motor today and found that desoldering wire worked very well to remove the solder from the old connection. :y
