Author Topic: window removal  (Read 3959 times)
flyer 0712
window removal
« on: 22 January 2015, 11:57:20 »
To remove the large  door window from the rear door ,does the window regulator have to be removed and if so how is it attached to the door and is it an easy job to do..ta much  :-\
Re: window removal
« Reply #1 on: 22 January 2015, 12:03:24 »
As per Haynes :y you'll need a drill, rivets and a rivet gun...
flyer 0712
Re: window removal
« Reply #2 on: 22 January 2015, 12:45:22 »
Cheers Al,  will have ago at that then, :y
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: window removal
« Reply #3 on: 22 January 2015, 18:27:35 »
If you don't have access to a rivet gun you can use nuts and bolts. I used counter sunk bolts and loctite, meant to replace them with rivets when got the chance.
5 years later, still to swap them
If it aint broken, you aint trying hard enough
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: window removal
« Reply #4 on: 22 January 2015, 18:57:58 »
Yep, nuts and bolts on refitting  :y
Don't go too crazy drilling the rivets out. When I did this at school for the first time I pretty much destroyed the tang that the upper rivet was attached to. Don't do that  ;D
RIP Paul Lovejoy
flyer 0712
Re: window removal
« Reply #5 on: 22 January 2015, 21:21:04 »
Any idea what diameter rivets or bolts required...nice to have all at hand to do the job in one go.. :y
