Author Topic: Omega 2.2 petrol 2003 manual possible engine temp problem  (Read 3690 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 29 January 2015, 10:34:50 »
In winter or summer time with the air-con on, should the engine temp stay fairly stable around 85 - 92, if the car is idling or doing 70mph?
As soon as I go down the motorway the temp drops from around 92 to around 65 depending on outside temp and speed.
I have noticed that all the rad fans are on when using air-con. No matter if its winter or summer. Is this normal?
Thanks
Re: Omega 2.2 petrol 2003 manual possible engine temp problem
« Reply #1 on: 29 January 2015, 10:49:43 »
air con on the fans run continually .. totally normal.
Temp dropping at speed .. does it take a long time to warm up as well ?? If so .. thermostat stuck open .. needs a new thermostat
Andy A
  • Bristol UK
« Reply #2 on: 29 January 2015, 12:13:01 »
Yes it takes a while to warm up.
Do you know if the thermostat is separate or an all in one part with the housing?
Eurocarparts is showing both.
Thanks
« Reply #3 on: 29 January 2015, 12:17:35 »
Get it separate Andy
Andy A
  • Bristol UK
« Reply #4 on: 29 January 2015, 14:02:00 »
Will do Rob. Will I need a new gasket?
« Reply #5 on: 29 January 2015, 14:48:17 »
Ideally yes, but a thin streak of instant gasket around the original seal will do just as well if it isn't broken :y
Andy A
  • Bristol UK
« Reply #6 on: 29 January 2015, 16:44:39 »
Thanks all for your help.  :y
Twintop
  • cruising
    • V6 3.2
« Reply #7 on: 29 January 2015, 22:28:04 »
Ecp were doing thermostat and housing for about £5 on flebay  :y
Black mv6 manual,3.2 v6
550 bhp supercharger with 100bhp wet nitrous kit
« Reply #8 on: 30 January 2015, 08:38:59 »
The 2.2 stat is piss easy to change, and even dealer gasket is cheapish. From memory, dealer price for stat is a steep £25 though :(
Don't forget to add coolant to the budget as well
Andy A
  • Bristol UK
« Reply #9 on: 30 January 2015, 09:29:22 »
Anyone know what the torque settings are for the bolts?
Is it best to replace from dealer or will any do the same job?
Thanks
« Last Edit: 30 January 2015, 09:32:28 by Andy A »
« Reply #10 on: 30 January 2015, 15:21:35 »
Thanks
The original bolts can be reused and the torque is 8nm iirc :-\
« Last Edit: 30 January 2015, 15:27:31 by PhilRich »
« Reply #11 on: 30 January 2015, 16:11:34 »
15NM/11lbft according to the book of bloks :y
« Reply #12 on: 30 January 2015, 18:19:37 »
Thanks Al, I need someone to keep me right! ;D :y
Andy A
  • Bristol UK
« Reply #13 on: 30 January 2015, 19:01:48 »
15NM it is then.
