Pages: [1] 2 3  All   Go Down
Author Topic: Cam cover gaskets  (Read 9732 times)
Twintop
  • cruising
    • V6 3.2
Cam cover gaskets
« on: 30 January 2015, 15:30:19 »
as ive done alot of mods on my engine with very good results and a lot of money thrown at it with custom parts made especially for me,why do vx charge so much for a bit of rubber,where ive actually used other makes and never had a problem,maybe because im using very high performance oil and it gets changed every 3k ,thought please.
Black mv6 manual,3.2 v6
550 bhp supercharger with 100bhp wet nitrous kit
Re: Cam cover gaskets
« Reply #1 on: 30 January 2015, 15:37:19 »
AGP ones working ok on mine to date, around £5 a bank ;)
Twintop
  • cruising
    • V6 3.2
« Reply #2 on: 30 January 2015, 15:42:03 »
Cool,these are 1 of the items that ive never had to get custom made,all tho money is no object to me,i begrudge paying stupid money for a bit of rubber,now if it was a sexy cat suit with a 6' tall busty blonde then hell yes i could justify it  :y
« Reply #3 on: 30 January 2015, 15:42:13 »
The issue is a combination of things...
Firstly, cheaper pattern gaskets tend to harden and go brittle over time.
Secondly, if the breathers aren't kept clear then internal pressure forces oil past the failing gaskets leading to oil leaks and potentially killing plugs/leads/coil packs.
As I'm sure Dbug will testify, Allgermanparts supply an alternative to the GM ones which do seem to be upto scratch :y
Twintop
  • cruising
    • V6 3.2
« Reply #4 on: 30 January 2015, 15:46:42 »
Umm interesting,but i think with my setup breathers would never be blocked up,due to the oil i use,how often its changed etc,never had no problem with gaskets leaking using pattern parts tho,and bearing in mind my beast is not standard spec either  :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #5 on: 30 January 2015, 15:49:55 »
So do you buy the cheap and nasty cam cover gaskets  :-\
Twintop
  • cruising
    • V6 3.2
« Reply #6 on: 30 January 2015, 15:52:45 »
Lol yes i do and not ashamed to admit it,if it works and does the job,thats fine with me.
Steve B
  • Leicestershire
« Reply #7 on: 30 January 2015, 15:53:55 »
and they never fail  :-\
And how many miles they been in the car now
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #8 on: 30 January 2015, 15:54:46 »
The difference seems to be that on the cheepo ones, the half moon at the back tends to go brittle and subsequently leak.
You pay your money, you take your chances I suppose ..................
dbug, how long / miles has your cheepo ones been fitted ?
EMD
  • Noofhampton
    • 95t
« Reply #9 on: 30 January 2015, 15:55:11 »
How much are genuine cam gaskets now , last time i heard they were about £105 a set  :-\
Omegatitis
Twintop
  • cruising
    • V6 3.2
« Reply #10 on: 30 January 2015, 15:58:10 »
I would rather have the 6' tall busty blonde in a rubber cat suit than pay that much for a rubber gasket .
Steve B
  • Leicestershire
« Reply #11 on: 30 January 2015, 16:00:59 »
This one is gonna drag on   ;D ;D ;D ;D
« Reply #12 on: 30 January 2015, 16:01:08 »
Perhaps... but if they only last a fifth of the time, then the GM ones work out cheaper once labour time is factored in...
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #13 on: 30 January 2015, 16:02:59 »
About £42 a side with o seals, on trade club :y
« Reply #14 on: 30 January 2015, 16:04:48 »
That's not too bad :y
Pages: [1] 2 3  All   Go Up
