Author Topic: Rear spring lengths amd spec...  (Read 1918 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« on: 02 February 2015, 18:31:03 »
I'm getting all confused now. I need a pair of springs for the rear of my explod saloon, 2003. I'm tempted by a set that have been offered from an explod 3.0, seller has kindly measured them for me and theyre the same length as mine.
 Did they come in different spring rates? Ive always loved how mine rides, handles, and sits.
For reference the ones I'm looking at are approx 27cm - anyone know the length of a standard MV6 spring? :y
  • Auckland
    • Mazda MPV
Re: Rear spring lengths amd spec...
« Reply #1 on: 02 February 2015, 23:06:15 »
I don't think you can tell much from the free length with spring off the car especially as they have already seen some use.
If they are cheap then you haven't got much to lose. If they are not cheap then don't.........
elvin315
  • Catskill, New York, USA
  • Catera...Cadillac's unloved stepchild.
« Reply #2 on: 03 February 2015, 02:17:14 »
I know it's dangerous to assume, but if your car is ex-plod and the seller's springs are ex-plod I would think they're the same length and rate.
Is that all there is, is that all there is
If that's all there is my friends, then let's keep dancing
Let's break out the booze and have a ball, If that's all there is
« Reply #3 on: 03 February 2015, 11:30:31 »
I might just have to pop down and see him, and compare the stiffness, somehow... Ta chaps! :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #4 on: 03 February 2015, 11:54:11 »
Will try and measure mine (they're off the car, by the way  ::) ) if I get chance tonight, but suspect someone else will beat me to it before then.
« Reply #5 on: 03 February 2015, 17:02:44 »
I have a wedding to attend up that way in October... ::)
tidla
  • solihull
« Reply #6 on: 03 February 2015, 17:14:54 »
Is fitting spring from another 10 years + motor a good idea?
Although more money than the saloon,their not that expensive new.
http://www.ebay.co.uk/itm/Sachs-24339749-Rear-Coil-Spring-Vauxhall-Omega-Estate-/400853581974?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AOmega&hash=item5d54bc4096
« Reply #7 on: 03 February 2015, 17:17:52 »
The plod springs are beefier, and fitted as a set, wear isn't such an issue replacing one.
