Author Topic: Thank you again  (Read 5662 times)
Thank you again
« on: 04 February 2015, 22:53:09 »
This time specifically to Marks DTM Calib, how gave up his evening to fit new springs to the front of the Battlebus. In a under 90mins :o
I tell you what, it drives a damn site better than it ever has.  OK, its still as flat as a pancake, but it drives quite nicely, predictably, and no rattles which I don't understand.  And the knocking over bumps has gone :)
Cheers Mr DTM, much appreciated.  Lets see if my grumpy MOTer is happy now :)
Re: Thank you again
« Reply #1 on: 05 February 2015, 08:32:18 »
Not a problem, good to see you (again!)
We really must sort the 'go' out on that bus at some point
Re: Thank you again
« Reply #2 on: 05 February 2015, 18:02:52 »
Transplant a bigger power plant?
Re: Thank you again
« Reply #3 on: 05 February 2015, 20:35:56 »
Yeah, bit too scared to touch it before end of March in case I break it. After March, the pressure is off ;)
It didn't half use some fuel on the way home last night...   ...it was reading just under half a tank when I leave yours, flashing fuel light when I got home  :-[
Re: Thank you again
« Reply #4 on: 05 February 2015, 20:36:42 »
Probably easier to just fix the one that's in there.  That said, not sure the top quality tyres could handle much more power ;D
Re: Thank you again
« Reply #5 on: 05 February 2015, 21:04:42 »
Booked in for retest tomorrow
Re: Thank you again
« Reply #6 on: 05 February 2015, 22:45:24 »
Good luck :y
If it passes, you could treat it to the 3.0 CDTi lump :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Thank you again
« Reply #7 on: 05 February 2015, 23:08:53 »
Good luck :y
That would make it talk  :y
other rides
Re: Thank you again
« Reply #8 on: 05 February 2015, 23:14:10 »
If a bit tail happy/nose heavy... ::)
Re: Thank you again
« Reply #9 on: 06 February 2015, 08:02:58 »
Good luck :y
No point, the 1.9 has as much torque and is easily tuned to way beyond what the 3.0 can produce even when chipped.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Thank you again
« Reply #10 on: 06 February 2015, 08:37:25 »
Nobody biting?  Nobody ::) ::) ::)
henryd
  • west cornwall
Re: Thank you again
« Reply #11 on: 06 February 2015, 09:18:20 »
Good luck :y
True but a four banger will never sound the same as a creamy V6 8)
other rides
Re: Thank you again
« Reply #12 on: 06 February 2015, 09:39:31 »
Good luck :y
Creamy? It's still a skeleton masturbating in a biscuit tin diesel. ;)
  • Online Online
Re: Thank you again
« Reply #13 on: 06 February 2015, 10:59:15 »
Good luck :y
 :D ;D ;D ;D ;D ...the mind boggles.
Re: Thank you again
« Reply #14 on: 06 February 2015, 11:48:08 »
Well I'm biting my fingernails. Does that count?
