Thoughts on my MP3 install please
Started by VXL V6, 12 February 2015, 19:50:52
Sorry for the poor quality phone picture
Head unit modified to take direct input  :y
Webby the Bear
RIP Paul Lovejoy
Mr.OmegaMan
Top job :y, It's one of those problems with old cars these days unless your still buying all your music on CDs  :-\
Steve B
Quote from: VXL V6 on 12 February 2015, 19:50:52
May i ask what needed doing. And can the 206 do this  :-\
Darth Loo-knee
Quote from: BIGtime on 12 February 2015, 20:32:09Head unit modified to take direct input  :y
QuoteMay i ask what needed doing. And can the 206 do this  :-\
CCR2006? Yes it can. The process involves intercepting some of the wiring within the head unit, and running the feeds and returns to a switch (so you can select CD player or MP3 Player) and then connecting a line level device to the selector switch - in my case the little panel mount MP3 player.
You have to work out how your going to route the cable and what power source and device you want to use. I wanted to have something that could be hidden away easily without having to detach cables etc so this device fitted the bill, I just shut the ashtray! The ashtray has the benefit of having a readily available power source! All connections I made are soldered and a fuse was also incorporated in the power feed, the ashtray has seen some modifications in order to accommodate the install.
Steve B
Quote from: VXL V6 on 12 February 2015, 20:55:32
Well it looks great.. When do you wanna do mine  ;D ;D ;D
Steve B
So the mp3 player feeds 3 wires L. R and a common -   And you have powered it from the 12v cig lighter and dropped the voltage..
Quote from: BIGtime on 12 February 2015, 21:14:17
Correct, but you'll also need to return the signals back via a switch if you want to keep the CD Changer working. MP3 device i'm using is happy with 5v - 14v without issue but I have put a fuse in circuit.
Steve B
Quote from: VXL V6 on 12 February 2015, 21:28:38
Which one is that  :-\ is your mp3 player output sort of joined in with you cd output then,before its amped  :y
Quote from: BIGtime on 12 February 2015, 21:32:47
Yep, that's right.
Steve B
Last Question  ;D ;D ;D Whats the make of that mp3 player  :y
I can't pronounce it  ;D
But suffice to say it's an incredibly cheap Chinese job off Ebay!
Does also have a remote control, FM tuner, Line in (for another device) and supports SD/MMC and USB memory sticks, of course if you want to shut the ashtray with the memory card still installed you'll need to use an RS-MMC card!
